It is currently Mon Aug 04, 2025 2:02 am
 Post subject: Sump plug
PostPosted: Thu Nov 19, 2015 5:57 pm
I went to fit my new long magnetic sump plug but it swims around in the hole ?
The original plug is 3/4" 10 UNC and the magnetic one is 5/8" 11 UNC.
Which one is the correct size.
 Post subject: Re: Sump plug
PostPosted: Thu Nov 19, 2015 6:13 pm
The one that fits!
PostPosted: Thu Nov 19, 2015 6:25 pm
Someone has stripped the thread and tapped it bigger. 5/8 was original.
PostPosted: Thu Nov 19, 2015 6:58 pm
The old plug has a 6mm hole drilled down inside it.
I'm tempted to cut the shaft off the magnetic one and drill the hole a little bigger and drive the shaft of the magnetic one in and then refit the magnet to the end of it.
Does this sound feasible ?
PostPosted: Thu Nov 19, 2015 8:00 pm
Just make up some epoxy resin or something like that to glue the shaft/magnet into your plug.
Just try to keep it straight.
Or did you say that the old plugs hole is smaller then the shaft on the new plug? Doesn't look it in the picture but if so then just do as you mentioned.
PostPosted: Thu Nov 19, 2015 8:02 pm
Works a treat.
PostPosted: Thu Nov 19, 2015 8:34 pm
Mini_mad_mat
I don't trust epoxy. If it's not prepared/mixed perfectly the results can be poor.
I'd hate to have the magnet come loose and leap onto the gears :shock:
Mick
Yes, I think the "press fit" option is better.
Is a magnet really necessary. I'm only fitting one because I can and others do as well.
Follow the leader :roll:
PostPosted: Thu Nov 19, 2015 9:53 pm
Magnet is a good idea. Press fit the one out of the new plug.
PostPosted: Thu Nov 19, 2015 10:03 pm
Why not use a magnet on the filter if you can't get one on the sump plug?
PostPosted: Thu Nov 19, 2015 10:27 pm
Good point.
Since putting a rare earth magnet on the spin-on filter, I get sfa debris on the sump plug one.
However I've not tried one on an old cartridge filter. Their filter can may be too thick to get a decent magnetic field through it. Need to trial fit a magnet on the bench, then throw some iron filings in there and have a look see at how it holds put.
PostPosted: Fri Nov 20, 2015 12:42 am
Good point.
How about putting it inside the filter? A disc with a hole the right size might work?
PostPosted: Fri Nov 20, 2015 4:49 am
You could sit a small one inside on the bottom, no need for a hole in it. A 20mm one would do. It won't move.
PostPosted: Fri Nov 20, 2015 5:26 pm
What size magnet do people use on the spin on filters?
PostPosted: Fri Nov 20, 2015 5:36 pm
I have three 50mm (l) x 10mm (w) spaced equally.
PostPosted: Fri Nov 20, 2015 6:24 pm
I use 2 x 25mm ones but a 20mm one is OK.
