It is currently Tue Aug 19, 2025 6:36 am
PostPosted: Sun Nov 15, 2015 10:01 pm
I was wondering if there is any difference between an 850 left hand petrol tank and a mk1 cooper s left hand petrol tank?
PostPosted: Sun Nov 15, 2015 10:14 pm
The senders are different. You cannot get the 850 sender units anymore.
They screwed in, where as all others were a turn to tighten type washer thing that kept them in
PostPosted: Sun Nov 15, 2015 10:17 pm
So therefore you can't put a cooper s sender unit in a mini 850 fuel tank?
PostPosted: Sun Nov 15, 2015 10:18 pm
So then are deluxe fuel tanks the same as cooper s?
PostPosted: Mon Nov 16, 2015 6:03 am
Yes, identical.
PostPosted: Mon Nov 16, 2015 4:51 pm
I see why my fuel gauge doesn't work therefore I will go ahead and get a deluxe or later fuel tank with sender and that should fix my problem.
One last thing is that I need to vent both tanks. According to my readings the rubber pipe from each tank runs under the rear parcel shelf and is joined by a tee and then where does it vent out?
Pictures would be helpful
Thanks again
PostPosted: Mon Nov 16, 2015 5:48 pm
Thanks again
My understanding is they each run across the parcel shelf, but exit separately through the floor.
LH tank through RH floor grommet, RH tank through LH floor grommet.
This prevents fuel from the higher tank overflowing the lower one, when parked on an angle.
PostPosted: Mon Nov 16, 2015 7:10 pm
I can convert the 850 sender to work with a later fuel gauge and vice versa :)
The changeover date is sept 64 which means that early English cooper s 1275, 1071 and 970 along with 997 and most Aussie 998 are in this category
I run a clubman long range tank in my 997 and an even more obscure combo of two tanks in my mini marcos
1960 Morris Mini Minor
