It is currently Mon Jun 23, 2025 2:07 pm
Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: 1220 auto build
PostPosted: Mon Oct 05, 2015 6:54 pm
Anybody have a particular favourite carbide tip they recommend?
I might steal Docs trick of setting it up on drill press ....
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Mon Oct 05, 2015 6:55 pm
Then their gonna love the caustic soda bath their currently in Timmy :)
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Tue Oct 06, 2015 11:59 am
Is this bad?
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Tue Oct 06, 2015 12:14 pm
Pretty crusty but I've seen worse.
Give it a nice long soak in molasses and water, 1:3 ratio. Or vinegar.
Top face of head can be decked a few thou to clean up when the rust monster has gone.
PostPosted: Tue Oct 06, 2015 12:53 pm
Doc there is a chunk taken out of the top right stud hole , is it imperative to have this recess all nice n flush?
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Tue Oct 06, 2015 1:05 pm
If not flush there the water can get into the thread.
After you derust it, fill that bit with JB weld (filled epoxy) or similar.
Run a 5/16 UNC plug (bottoming) tap into the threads to clean them, but do NOT tap any deeper.
PostPosted: Tue Oct 06, 2015 1:37 pm
This was the result of the caustic soda bath with a high-pressure waterblast afterwards, then spraying some metal prep conditioner over the whole head. Ended up getting this funny white powdery stuff:)
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Tue Oct 06, 2015 1:39 pm
Thanks doc .
I think I might try my new silicon bronze rods on this to build it up ;)
Simonw
Brisbane QLD
- 1969 Mini K
 Post subject: 1220 auto build
PostPosted: Tue Oct 06, 2015 1:45 pm
The head measured 69.7 or 2.7440"
I'm guessing this has been decked before as the original is 2.75" or 69.85mm right ?
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Tue Oct 06, 2015 1:53 pm
If you are going to braze it, preheat the whole head first to avoid cracking. It's cast iron.
Put head on a 2 burner camp stove. Light.
Open beer, drink.
Repeat last step...
When all the paint etc has burned off you are ready to go.
Braze head. I use nickel bronze, it's less runny, and stronger than manganese bronze. Use bronze welding flux, not the stuff on the coated rod.
Turn stove off.
Erect a teepee or frame well above the stove and cover with blanket/doona/whatever.
Leave to cool, it'll take hours. Have another beer or 3.. :)
If you are going to MIG or TIG it with silicon bronze, I would still preheat it as above. Maybe a bit less.
[edit] That height may be original, the 2.750" is a nominal measurement.
PostPosted: Tue Oct 27, 2015 3:17 am
have you guys looked at the minisport 202 head, it's an exchange deal with oversize cooper inlets. I would have thought oversize exhaust in these would be a boon also.
Is this a viable option or to much $$$.
PostPosted: Tue Oct 27, 2015 5:35 am
The metal prep will leave a coat of I think zinc oxide on bare metal surfaces to inhibit the rust and allow for a nice contact for painting. Shouldn't be too much to worry about though and will always clean off with another blast.
Rob Forsyth
Miniot!!
PostPosted: Tue Oct 27, 2015 6:37 am
It seems a bit on the high side for essentially a standard head with an unleaded conversion.
PostPosted: Tue Oct 27, 2015 12:11 pm
Unless your chambering and porting, the miniskirt head will offer nothing more than your local head shop could do , probably for a lot less .
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Tue Oct 27, 2015 1:50 pm
lol, miniskirt. that's all I will see from now on TY.
