It is currently Sun Jul 13, 2025 10:13 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 513, 514, 515, 516, 517, 518, 519 ... 568  Next
PostPosted: Fri Jun 05, 2015 1:08 am
Rover Cooper
went into the man cave today, removed the winter coat, lifted the bonnet, thought to myself, WHAT THE &#%K! closed the bonnet, replaced the cover, walked over to the fridge, smiled and settled in for the afternoon with some internal lubrication and completely ignored the constant knocking on the locked door, can't think who it might have been, :-/
PostPosted: Fri Jun 05, 2015 3:01 pm
I've been trying to find a spot for everything in the new garage. The shelves are rated to 750kg each, which is more than a mini per shelf :D
PostPosted: Fri Jun 05, 2015 8:40 pm
Phil 850 wrote:
That's really sweet !
While I love my roundy, I have always hankered for a "modern" (clubman) mini.
Thanks Phil
Black is the new Black
PostPosted: Sun Jun 07, 2015 4:58 pm
Gave it a grease and oil change yesterday
today me and JC went for a run down to Kiama
down through Jambaroo , Some good mini roads :D
PostPosted: Sun Jun 07, 2015 5:10 pm
Took a look at the old girls for the first time in 4 weeks. Need a stack of time put aside to keep working on the 62. Now have a pair of heritage guards to fit up.
PostPosted: Sun Jun 07, 2015 6:57 pm
Good to see you out & about , nice photo 8) .
PostPosted: Sun Jun 07, 2015 8:02 pm
Drove my 850 to Springwood to the custom and hot rod show.
Must have been about 7 minis on display along with all the other cars.
Great day.
850 ran faultlessly :D
PostPosted: Mon Jun 08, 2015 7:10 pm
Replaced my condenser, cleaned and gapped my plugs and fettled my timing a bit. Running pretty sweet now.
Added a couple of switches with some very 70s labelling.
Finally removed my ply dash fascia and vinyl wrapped it. changed my starter button from cheezy light up red bling to the chrome goodness.
I also decided to recess some rare earth magnets in the fascia (after wrapping it hahaha) so I can slap my phone against it.
That's my long weekend dusted. Now enjoying a frothy.
1974 Leyland Mini S
1275cc with some zippy bits
PostPosted: Mon Jun 08, 2015 8:19 pm
Towed it home from Hay.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Jun 09, 2015 7:51 am
:shock: :shock: :?
PostPosted: Tue Jun 09, 2015 8:22 am
Spent the weekend down the south coast in Huskisson, took the mini down with us and got plenty of attention in the caravan park. On the way home we were driving near kangaroo valley and every now and then heard a small 'ting' like a rock flicking up underneath.
Decided to check it out and pull over, turns out the nut had come off the rubber mount for the exhaust and it was hanging about an inch off the ground! Had to steal a 1/2" nut from my booster to get her home, but all was good!
PostPosted: Tue Jun 09, 2015 8:36 am
next time you come down south let me know ill come join you for a cruz.
PostPosted: Thu Jun 18, 2015 8:21 am
Drove the mini to the garage, had the new disc brake conversion fitted and drove the mini home. Got the kit from the UK months ago and have had it sitting in corner of the shed. Was planning on doing the job myself but am in the middle of a house extension at the moment and my shed is so full of stuff from the house and the builders bits and bobs I can just about get the car in and out !! Decided it would be money well spent to just get it done and enjoy driving the car and boy was it a good decision. I cant believe how different it was driving it with the disc brakes, they haven't even bedded in yet but difference in stopping power and confidence that the car will stop is amazing.
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Sun Jun 28, 2015 6:42 pm
Replaced reg unit on a dynamo car with one from 1964. Voltage now 14.6v. (Set for calcium battery)
They did make things to last back then
PostPosted: Mon Jun 29, 2015 10:28 am
Over the weekend - Finished doing the timing as best as I can for now, cleaned up the new ECU wiring & put the dash back on, tested lights etc are working, removed the gear-change rod & stabiliser for fixing/adjustment.
I then realised that I haven't got any power to the sound system.... :roll:
Once the gear-change is done the next job is to re-fill the gearbox with oil & take it to be fixed so it doesn't leak.
I might sort out some power to the head-unit too.
1.8L Sunshine - Legal, legit & lovinit
