It is currently Mon Jul 14, 2025 11:33 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 506, 507, 508, 509, 510, 511, 512 ... 568  Next
PostPosted: Thu Feb 19, 2015 2:47 pm
timmy201 wrote:
I installed a new side mirror
No holes need to be drilled in the door which is nice! I'll trim the bolt down a little to neaten it up inside
Or get a domed nut.
PostPosted: Thu Feb 19, 2015 3:54 pm
A chromed or s/s domed nut would look right there..
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Thu Feb 19, 2015 3:57 pm
And a rubber seal/ grommet under the base to seal it...
Minis..
1975 van
PostPosted: Fri Feb 20, 2015 7:04 pm
Is it practical when the window is open?
PostPosted: Fri Feb 20, 2015 7:15 pm
Got a new speedo cable and I can now see how slow or how fast I am going.
1972 Leyland Mini Clubman
2000 Honda CBR929RR
PostPosted: Fri Feb 20, 2015 7:56 pm
A rear view mirror with Zoom feature, just slide the window back for wide angle, forward for telephoto 8)
PostPosted: Fri Feb 20, 2015 11:14 pm
Haha, that's pretty clever actually
PostPosted: Fri Feb 20, 2015 11:22 pm
Lol... love it
Minis..
1975 van
PostPosted: Sat Feb 21, 2015 7:29 pm
Today we replaced the timing cover gasket, cleaned the top of the block in prep for the new head gasket, taped up the head and resprayed it black AND ordered my new number plates. 67-MIN, to finally represent the real year it was built :D.
Another busy day tomorrow!
PostPosted: Sat Feb 21, 2015 7:35 pm
Not much today. Got her running a bit better. Bled the brakes then took it for a spin up the street. Still cant get 1st 2nd or reverse...
Minis..
1975 van
PostPosted: Sat Feb 21, 2015 7:38 pm
A new battery and a jerry can of fuel so I could get the dark blue 850 running in case I had to get the cars to higher ground. Lifted the high value parts and tools up to the high shelves in the shed.
The creek peaked late in the afternoon at a very safe level so I needn't have bothered.
M
PostPosted: Sat Feb 21, 2015 8:03 pm
Better to be safe than sorry mokesta
Minis..
1975 van
PostPosted: Mon Feb 23, 2015 5:43 pm
I pulled the LF driveshaft & hub out, as it's due for new Timken wheel bearings and balljoints after 130,000 miles in 25 years.
Found the CV was worn where the bearing sits, also the outer splines of the GT driveshaft was damaged where the spring clip sits.
So, it's also getting a new (Italian) CV and a Mini Deluxe driveshaft. :) My U/Js are Hardy Spicer but the spline is the same.
I crossdrilled the new CV's single split pin hole so I only need ~150ft/lb torque to align the split pin.
PostPosted: Sun Mar 01, 2015 12:50 pm
Sprayed the inserts on a steering wheel silver to match the dash and installed the new steering wheel.
2000 Honda CBR929RR
PostPosted: Sun Mar 01, 2015 1:16 pm
After the discussion the last week on old school wheel alignments, I set about performing a four wheel alignment on the red mini.
I'm aligning them all to a center line chassis datum front and rear, and also doing the camber on all four wheels.
