It is currently Tue Jul 29, 2025 12:46 pm
 Post subject: 1275LS engine Prefix?
PostPosted: Thu Nov 06, 2014 2:32 pm
Hi there
I have been doing a little research about the engine in my 66 Deluxe. (It is a 1275 and I have fitted an SC12 blower). I purchased the block which was listed as a 1100S engine off ebay (in 2005). The engine number is 12H902UH which would possibly suggest a 1275LS and not an 1100S as listed. Does anyone more knowledgable know what it is from??
Rick
P.S - Incidently, my 2nd car was a 1275LS HI Ho in 1995 and was awsome (Before it ended up on it's lid!)
(First car was a 1961 Morris 850 powerhouse)
1310 SC 1969 Morris Deluxe - 15psi boost
1293 1968 Morris Deluxe Miglia - 45 Weber
HSV Maloo Z Series - Comp Cam - 300rwkw
Ford DF LTD - 5Ltr
PostPosted: Thu Nov 06, 2014 7:19 pm
I believe the 1275 LS blocks had pushrod covers at the back of the block, 1100s are solid.
PostPosted: Fri Nov 07, 2014 5:56 am
Nope it's the GTs that had covers on the back (Cooper S block).
1275LS block is solid, looks like an 1100S one, but different engine prefix.
1100S (most) is 12YD/Ta/H prefix, I'm not 100% sure of the 127LS one. But 12H/902/U/H rings a bell. Mini King book agrees.
PostPosted: Fri Nov 07, 2014 6:04 am
12H902UH engine is a 1275LS engine .That is what's in my 78 LS.
Regards Felix
1967 Morris mini Deluxe
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
1982 Jaguar XJ6 series 3
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Fri Nov 07, 2014 7:42 am
Sweet. Worth more than 1100s engine I would imagine. Yes, the block is solid (no pushrod covers).
Good to know as I would like to restore a 1275LS at some stage. Might be able to pickup a body less engine some day. (I know, he's dreaming)
Ford DF LTD - 5Ltr
PostPosted: Fri Nov 07, 2014 11:51 am
12H902 is a 1275LS prefix.
Mine is 12H897UH whcih doesn't match any codes I have found. Both of the mechanics I have spoken to about it say it is correct and someone has mis-stamped it.
As it is an early 1275LS (July) it may be the prototype :lol: or early in the batch before they knew what the number should be. Going out on a limb there but hey who knows..
Alec
PostPosted: Fri Nov 07, 2014 1:15 pm
OK - Thanks everyone. Good to know. It is a strong engine and 40thou over bore. Has had 9psi of non intercooled boost thrown into it for a few years now with no dramas.
Ford DF LTD - 5Ltr
PostPosted: Fri Nov 07, 2014 1:17 pm
John Smidt's Mini King book also lists 12H897UH as a 1275LS motor.
PostPosted: Fri Nov 07, 2014 5:33 pm
Thanks Doc.
Alec
Users browsing this forum: Andosoft, Bing [Bot] and 90 guests
