It is currently Tue Jul 22, 2025 2:47 pm
 Post subject: Fuel tank sealer
PostPosted: Sat Nov 01, 2014 9:16 am
Came home Monday to find fuel is leaking into the boot :cry:
checked all the hose fittings , but they are not the problem ,
looks like it is leaking through the seam.
pulled the tank out and the surface rust inside above the fuel level is not good :evil:
I remember something about a fuel tank treatment to coat the inside of fuel tanks to stop this rust and seal the tank,
Does anyone know what it is and has anyone used this with success ?
Mark
 Post subject: Re: Fuel tank sealer
PostPosted: Sat Nov 01, 2014 10:40 am
This is the stuff. Pour it in I believe and roll the tank hither and thither to coat the inside.
http://www.por15.com/POR-15-Fuel-Tank-Sealer_p_64.html
PostPosted: Sat Nov 01, 2014 10:45 am
KBS do a kit for bike tanks , may work for you :idea:
http://www.kbs-coatings.com.au/shop/
PostPosted: Sat Nov 01, 2014 12:42 pm
I have used the por kit several times and always had great success. It is a 3 stage process that takes a few days to do while it dries in between steps. You can get just the motorbike tank size which is enough for a mini tank.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sat Nov 01, 2014 2:44 pm
Looked at the KBS web and watched their videos
They welded the tank up first
I like Por15 product , Used the Por15 and their chassis black on my sub frames
came out great and is as though as
Might ring VG auto Paints and see if they stock the Por 15 fuel tank stuff
I will do both tanks while I am at it
Mark
PostPosted: Sat Nov 01, 2014 2:50 pm
I'm sure I saw the POR15 tank sealer at VG's.
PostPosted: Sat Nov 01, 2014 3:09 pm
Thanks Doc
VG was where I got the other Por 15 products
I will give them a call
Mark
PostPosted: Sun Nov 02, 2014 2:16 pm
I have used the KBS kit recently on my recent mini project, works really well and sets like fibre glass resin. Only issue was the filter in the tank got clogged even though I had air blowing through while the resin set.
I have a kit spare as I bought 2.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Nov 02, 2014 3:08 pm
Hi Michael
Would one kit be enough to do 2 tanks ?
If so would you be interested in parting with your spare kit ?
Pm me if so
Mark
PostPosted: Sun Nov 02, 2014 3:27 pm
I have one of the motor bike kits and it was more than enough to completely cover the inside of one mini tank with a bit left over but not enough for two tanks
1969 Cooper "S"
1967 Mini Deluxe
Users browsing this forum: winabbey and 110 guests
