It is currently Thu Jul 24, 2025 2:39 am
 Post subject: Front Drum Hubs
PostPosted: Sun Oct 26, 2014 9:41 am
Are both the hubs the same on the front? as in, if you strip the front drum down to the basic hub, can I use any on either side?
One of my hubs is worn on the inside, bearings are loose on the outside and really tight on the inside.
Think I'd rather replace it to be on the safe side.
Thanks for any help..
 Post subject: Re: Front Drum Hubs
PostPosted: Sun Oct 26, 2014 10:12 am
no, they`re sided,, as in a left hub is a left hub & a right is a right
i have hundreds of them if you`re stuck
Matt
0407 135 656
(07)3399 99 99
PostPosted: Sun Oct 26, 2014 10:35 am
OK. How do I tell left from right? I'll check and let you know what I need. Thanks
PostPosted: Sun Oct 26, 2014 1:55 pm
Looking at before photos, it shows the grease nipples to the front with steering arm mount to the top. Looks like I need a drivers side hub
PostPosted: Sun Oct 26, 2014 6:24 pm
Upper and lower Ball joint Grease nipples face the front on both sides
Mini kingdom online has about 100 nos drivers side ones but no passenger side ones nos
I needed a passenger side one the other week and john let me go through the nos ones all drivers side ones but
I think it was $40-$45 for a nos one
Users browsing this forum: No registered users and 129 guests
