It is currently Mon Jul 28, 2025 12:32 am
 Post subject: Re: Rat Rod mini
PostPosted: Fri Oct 24, 2014 11:29 am
hmmm, Roller paint. . . Maybe ill look into it. .
that mini van roller d looks pretty damn good. . . any specific paints that's best suited to rollers?
Im cheap, and broke. so the cheaper the better!
1967 Mini Deluxe bucket of rust and mismatched parts powered by a 1360cc and a destroyed gearbox missing second gear :D Image
PostPosted: Fri Oct 24, 2014 1:13 pm
My mate used International Brightside Yacht Paint on his VN Wagon
If i was going to do it, I would use the exact same process he did (as described in the thread I linked earlier)
1975 Hairy Lime/White Clubby
PostPosted: Fri Oct 24, 2014 5:06 pm
I think you'd struggle to get anything in primer with visible rust through a roadworthy in Queensland. And even if you did you wouldn't last on the road for very long.
You could always try plasti-dipping the whole car!
PostPosted: Fri Oct 24, 2014 5:07 pm
Plastic dip sounds expensive 0_0
Car has 0 rust so that's not an issue for rwc
PostPosted: Fri Oct 24, 2014 6:07 pm
Spray wrap is same as plasti dip http://www.spraywrap.com.au/ . From $65 for 4 liters, less than $300 to do the whole car.
When your ready to do it properly just peel it off and your good to go.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Fri Oct 24, 2014 6:49 pm
That is damn impressive, unbelievable really. 8)
PostPosted: Fri Oct 24, 2014 7:55 pm
Yep. People assume it was done with a spay gun.
most dont believe him when he tells them it was a $300 roller job.
I've seen plenty of "cheap" spray jobs that dont even come close.
Users browsing this forum: Bing [Bot] and 95 guests
