It is currently Thu Jul 17, 2025 4:57 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 481, 482, 483, 484, 485, 486, 487 ... 568  Next
PostPosted: Thu Sep 25, 2014 10:48 am
A quick clean and then a drive to celebrate its 40th anniversary of continuous, one family registration.
Well done old friend!
PostPosted: Thu Sep 25, 2014 5:48 pm
Got quotes for rollcages
1963 850 - laid up
PostPosted: Thu Sep 25, 2014 6:14 pm
Wow! Well done!
1998 Rover Mk VII
2001 Honda CBR 929RR (street)
2014 BMW S1000RR (track)
PostPosted: Thu Sep 25, 2014 6:44 pm
Wow! Well done!
That is a very healthy milestone. Well done. 8)
PostPosted: Thu Sep 25, 2014 6:47 pm
Jeez , that be a rarity wouldn't it 8) , well done .
PostPosted: Thu Sep 25, 2014 8:14 pm
Made up spacers for front subframe. When I pulled it apart it had two big steel spacers that were about a kilo each.....no joke.. I'm not exagerating. :wink:
I left them out when I put it back together, everything seem to line up fine without them. I was wrong, oops, I mean mistaken, I'm never wrong.
It was like putting the brakes on when I turned. :shock: So I manufactured them in ally, superlight racing spacers, should be good for an extra 10kph.
As the saying goes, an inch is as good as a mile. It clears, that's enough for me.
PostPosted: Fri Sep 26, 2014 10:39 am
Pumped the LH hydro up. It had a weep at the valve- which wasn't fully tight, and the original cap's seal washer was perished too.
Aldi O-ring to the rescue. :)
PostPosted: Fri Sep 26, 2014 2:05 pm
Looked at order update, breaks are here.
Nick
PostPosted: Fri Sep 26, 2014 2:54 pm
Took delivery at long last of our new Mini "Special". It's a tight fit in our carport, however the whole fleet does fit. Not bad for Northcote. :)
Dave
1965 Mk1 Cooper S Sprint/Hillclimb/Rally Car
2012 Land Rover Defender 90
PostPosted: Fri Sep 26, 2014 2:58 pm
Restoring my LS Contessas
Before and after shots.... Very happy with the results!
PostPosted: Fri Sep 26, 2014 3:36 pm
They turned out really nice!!
PostPosted: Fri Sep 26, 2014 3:49 pm
Cheers, just a couple coats of clear once there all polished :)
PostPosted: Fri Sep 26, 2014 8:16 pm
Holly crap , that's impressive!!
PostPosted: Sat Sep 27, 2014 7:21 pm
Painted the rear subframe and components in a bit of chassis black. Bent some new brake lines for it also.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat Sep 27, 2014 8:17 pm
Hosed the cat poo from the Mini's carpet. Cat is in hiding.
It was the mythical number three. Full blurter failure.
Users browsing this forum: No registered users and 34 guests
