It is currently Thu Aug 14, 2025 8:54 pm
 Post subject: How do these go together
PostPosted: Fri Sep 12, 2014 5:00 am
Picked up a pair of these while overseas. http://www.minispares.com/product/Classic/Drivetrain/CV%20Joints/GCV1102.aspx?0801&ReturnUrl=/search/classic/Pot%20joint.aspx%7CBack%20to%20search
Does the drive shaft just push into the rubber boot - no external fastening?
David L
PostPosted: Fri Sep 12, 2014 10:10 am
Yes, or at least that's how they are on my mini. The rubber boot folds around and sits on a flange on the drive shaft. If you pull on the drive shaft there is enough movement in the boot to allow it to extend out a few cm.
Drive shaft:
==||========(Outer CV)
Drive shaft with boot:
____
____/
Edit: The editor removes all spacing, so my horrible diagrams look even more horrible.
PostPosted: Fri Sep 12, 2014 10:15 am
Original boots had a clip around the rubber on the shaft IIRC, but these boots don't because they are already clipped to the pot joint..
PostPosted: Fri Sep 12, 2014 10:28 am
Interesting - not really surprised as the mechanic working on my mini previously has done some interesting work. Mine were attached to the shaft, but the rubber was thick enough to grab on quite strongly without the clip. The mechanic obviously couldn't be bothered putting it on.
PostPosted: Fri Sep 12, 2014 6:31 pm
Make sure the rubber aint rock hard on them like mine were from a supplier who gets there parts
Or get new rubber boots from mini kingdom online
Users browsing this forum: Bing [Bot], Steam and 271 guests
