It is currently Thu Aug 14, 2025 5:25 pm
 Post subject: Head gasket removal?
PostPosted: Wed Sep 10, 2014 6:44 pm
Diesel27 wrote:
It dont go so well inside engines.
So not a good lubricant then :)
 Post subject: Re: Head gasket removal?
PostPosted: Thu Sep 11, 2014 9:05 am
74Club-man wrote:
I've tried a scraper or two with no luck, tried a razor blade in a handle, no good.
I've also just watched a video on the CRC Gasket Remover and that stuff looks hard-core so I'm going to duck down the shop and pick up some of that stuff and give it a go.
Wear gloves it melts skin pretty good!
PostPosted: Thu Sep 11, 2014 9:49 am
Does this stuff work on the flywheel housing gasket, as after 20+ years these things are like removing concrete.. :x
PostPosted: Thu Sep 11, 2014 10:21 am
You can only try! Like I said before spray it onto a clean rag first then wipe it on. You see it bubble away and after about five minutes the gasket is like soggy toilet paper. It is pretty hard core so be careful.
PostPosted: Thu Sep 11, 2014 10:25 am
So is it acidic, or something else? If so might not be best on an alloy housing?
http://www.mini-hb.co.nz
PostPosted: Fri Sep 12, 2014 6:04 am
Not acidic, ( just went to their MSDS) safe on brass, aluminium etc... it is a solvent that attacks the gasket sealant( impregnated into gasket and i gather any sealant used) Contains methyl chloride, methanol, xylene and a butane type propellant....
I wonder if methanol by itself would soften? ( keep away from rubber etc) available cheaply in 20 litre drums and you could soak things like the clutch cover????)
PostPosted: Fri Sep 12, 2014 8:51 am
Good news on the gasket, after using CRC gasket stripper the pesky baked on gasket has been removed. It is a good idea to wear gloves as it does burn the human skin :( I used it as per the instructions, used a blade scraper to scrape off the gasket, gave it a high pressure wash, a rub down with steel wool, another high pressure wash and a spray with WD40 until I paint the block.......and it has come up a treat.
"Do not use on painted areas or plastic parts"
If it has tit's or tires....It'll take all your money!
74 Leyland Clubman S (scrap)
77 Leyland Clubman S
Users browsing this forum: No registered users and 132 guests
