It is currently Sun Jul 27, 2025 10:45 pm
 Post subject: Re: Engine Steady
PostPosted: Thu Aug 28, 2014 7:32 pm
boomini wrote:
Wow thats a pretty engine bay
But isn't that kink in the steady supposed to be around the other way to go around the hose..... :roll:
http://www.mini-hb.co.nz
PostPosted: Thu Aug 28, 2014 7:56 pm
yes, something to aim for and miss. but where is the air cleaner.
thanks for the photo willy, will go and fold some metal tomorrow.
the steady i have has no kinks, it is identical to the one at the rear of the engine.
Roundy Sedan project with/for daughter
PostPosted: Thu Aug 28, 2014 8:01 pm
Hey frank I see your in perth. Im pretty sure I will have one of the bulk head brackets here if your interested. Easier than making one.
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Thu Aug 28, 2014 8:04 pm
Yup got one here. Already sanded and painted in 2pac gloss black. $25
Minis..
1975 van
PostPosted: Fri Aug 29, 2014 12:20 pm
pm sent
PostPosted: Sun Aug 31, 2014 9:45 am
Does anyone know where I can get the thermostat end complete engine steady assembly without having to import one.
I like the look on the Minispares one, http://www.minispares.com/product/Class ... 20shop#tkc
PostPosted: Sun Aug 31, 2014 3:52 pm
Further to the above post, with a 1275 and Rod change box, should I also add the bottom engine steadies (gearbox to subframe) or is this overkill ?.
Phil
PostPosted: Sun Aug 31, 2014 4:40 pm
http://minisport.com.au/radiator-staybi ... -1275-head
http://minisport.com.au/firewall-bracketa-radiator-end
And no, it has very little advantage due to the pivot point (engine mount).
Physics 101.
PostPosted: Mon Sep 01, 2014 10:43 am
MinisPlus
New stock of 1275 Themostat end brackets are available at MinisPlus.
http://www.minis.com.au/minis/catalog/p ... cts_id=159
How can it be rusty when it's covered in so much oil?
PostPosted: Sat Sep 06, 2014 9:35 pm
Fitted my top engine steady !
Before
After
Another purchase from John Smidt
PostPosted: Sun Sep 07, 2014 1:13 pm
Bright shiny parts with new bolts always make a difference to an engine bay.
PostPosted: Sun Sep 07, 2014 3:05 pm
You'll note the "non slip" radiator bracket for when I am walking around in the engine bay.
Always got to be safety conscious !
I hope to progressively tidy things up once it's registered and I can actually use it rather than just work on it.
PostPosted: Sun Sep 07, 2014 4:06 pm
I did notice that.
It will be the last intact item on the car.
Users browsing this forum: Bing [Bot] and 83 guests
