It is currently Tue Aug 05, 2025 5:08 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: 1978 mini ls
PostPosted: Mon Aug 18, 2014 3:06 pm
The Later Leyland minis also had a spacer plate under the clutch master cyl, which in-turn , lowers the starting height of the clutch pedal,,, we take the spacer plate out & even have to bend the arm sometimes too
it`s best to try to get as much clutch pedal travel as you can, & fit a 3/4" clutch master cyl as well
that`s just what we do,,, other people may have other methods
PostPosted: Mon Aug 18, 2014 5:53 pm
Hi ,I have three 1275 LS's currently and all have the higher brake pedal . Over the years ive had a many more 1275 LS's and they have always had the higher brake pedal . My 998 LS and mini s have level pedals they are both drum all round and the moke Californian is disk and the brake pedal is higher . Hope this helps .
78 1275 LS HI-HO SILVER
78 1275 LS NUGGET GOLD
77 998 LS IRIDIUM GREEN
75 1098 S YELLOW DEVIL
82 1275 MOKE CALIFORNIAN HIGHWAY YELLOW
78 1275 LS NUGGET GOLD (IN PIECES)
76 998 SS NUTMEG
78 1310 VAN BLUE
70 AUSTIN 1800 SUGAR CANE
2015 HSV MALOO
PostPosted: Mon Aug 18, 2014 6:28 pm
Thanks all for the info,
Well it must be the design of the brake m/cylinder that brings the pedal higher than the clutch on the later minis.
At least I feel more confident now when I go to Karkraft to get my parts.
I think I will leave the clutch m/cylnder as is as ther eis nothing wrong with it.
1967 Morris mini Deluxe
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
1982 Jaguar XJ6 series 3
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Mon Aug 18, 2014 6:51 pm
Yes good idea leave it as is .Update on the 77 998 LS well it looks like I need to go to specsavers as I just went out to the garage and looked at the pedals and it is higher as well ,just not quite as high as the 1275 LS. So yes must be all later cars perhaps its the tandem master cylinder cars .
76 998 SS NUTMEG
78 1310 VAN BLUE
2015 HSV MALOO
PostPosted: Thu Aug 21, 2014 8:44 am
I got all the bits i needed from Karkraft yesterday,only problem is the GMC227 master cylinder I bought has a 1 off 12mm outlet on it and the adapter pipe kit they had did not suit my car(the pipe was too short).
Does any one know where I can buy a 12mm male to a 10mm female brake adapter,this way I can use my original brake line.
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Thu Aug 21, 2014 12:06 pm
I think you would have a fitting (or even the line) made up quickest at a brake shop. They will swage the fitting up pretty quick, even with the original line if you must. You only give up 3 mm when you take the old flare off.
Minisport SA advertise the kit http://minisport.com.au/dual-circuit-ma ... r-cylinder
But the end fittings are a couple of dollars each, and the pipe is cheap too. Probably save you a few dollars to have it made up.
PostPosted: Thu Aug 21, 2014 2:58 pm
Hi Mick,
I saw those lines at Karkraft yesterday but the are too short compared to my existing pipes.so I did not get them.
I am now thinking that the top m/cylinder connection thread on the new one might be different than the old one,seeming that the new cylinder has metric threads,
I will check it tonight.
I may have to get new pipes made up to suit.
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Thu Aug 21, 2014 7:15 pm
The new GMC227 master cylinder has 1x12mm and I x10mm fittings
also has a stepped bore , also the top and bottom outlets are swapped around , so you can not just put the 12mm fitting on the top pipe
Mark
PostPosted: Fri Aug 22, 2014 7:34 am
You are right Mark,
I just went and had a look at my existing set up and the front brakes were connected to lower connection on M/cylinder,
(with the new M/cylinder the front brake connection is at the top)
It appears I need the pipe kit (BAU5654) that runs from the M/cyl to the press reducing valve.This will also reverse
the connections on M/cyl.
When Karkraft showed me this kit it looked like the pipes were too short,but obviously there not.
regards Felix
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Fri Aug 22, 2014 1:33 pm
BAU5654 kit is for UK cars , they do not fit our cars
Ring John at minikingdom and ask him for BAU5654 A
PostPosted: Wed Aug 27, 2014 5:34 pm
I ended up getting the brake lines for the master cylinder from John at Mini Kingdom today and they fitted perfectly,Thanks John.
All I need to do is bleed the brakes on the weekend,I bled the master cylinder before fitting it so hopefully all will be OK.
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
