It is currently Fri Jul 18, 2025 11:20 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 469, 470, 471, 472, 473, 474, 475 ... 568  Next
PostPosted: Tue Jul 15, 2014 7:23 pm
after getting the overhauled head back it was seeping a bit o oil down the front of the head, I figured I had applied the spray on sealant too thick.
Simple I say just replace the gasket.
Then it starts to drip a little oil onto the pistons when resting.
easy just fit these stem seals.
the head is NOT coming off for the THIRD time this week so did this.
the long nose pliers are for wriggling the springs so as to locate the collets.
also used a piece of 10mm key steel in place of the pliers.
then wriggled the complete assy for fitting collets
It's easy once you know how.
PostPosted: Tue Jul 15, 2014 7:54 pm
Snazzy little bit of metal work there diesel.
PostPosted: Tue Jul 15, 2014 9:30 pm
Checked it started.... it did and now charging up the leyland mini battery
PostPosted: Tue Jul 15, 2014 10:25 pm
cheers Mick, hope it works.
PostPosted: Thu Jul 17, 2014 6:11 pm
Finally got around to fitting an engine steady to the radiator end of the motor. Got fed up after snapping the other end gor the 3rd time. Then fitted up the adjustable camber and castor kit to the front end. Must say a m8ni with negative camber looks mean.
Rodney
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sun Jul 20, 2014 5:23 pm
Printed off the measurements for the Doc's bush idler bearing puller and had a go at making it late last night. I'm no fitter and turner but I think its good enough.
I didn't have an o ring so I used a cable tie :wink:
I also didn't have an M12 tap so I used 1/2 bsw rod instead.
It work great. Big thanks Kev for your how to.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Jul 20, 2014 8:35 pm
Needed to replace the CV boot, so I pulled off the front hub and slipped the shaft out of the pot joint.
One whack with the lump hammer and off came the CV. Slipped the new boot on, replaced the CV and did up the clips. Decided to check the lube of the balls in the pot joint only to find there was only 4 balls. Searched and searched the garage for the other 2 balls but to no avail :-(
I'm starting to think there never was 6 in there in the first place :-/
It's a terrible feeling knowing you are missing two balls :-)
PostPosted: Sun Jul 20, 2014 9:41 pm
Wrassled with a smart looking electric blue clubman.
Pulled dizzy to bits, pulled carb to bits, broke carbon brush in dizzy cap, smacked head on bonnet hook, sprayed fuel across engine bay, drained and topped up hydrolastic suspension to correct height.
All in all good fun :)
PostPosted: Sun Jul 20, 2014 11:01 pm
Just a normal day at the office then! :P
5/72 Clubman Gt
PostPosted: Sun Jul 20, 2014 11:04 pm
Fitted up the negative rear camber brackets. Did a wheel alignment then took for a spin. Awesome too drive. A lot more confidence into the corners.
Minis..
1975 van
PostPosted: Mon Jul 21, 2014 12:53 pm
Not as Terrible as knowing your still have 4 there :shock:
PostPosted: Mon Jul 21, 2014 4:41 pm
Dropped my very recently acquired Mk2 Cooper S off for a Roadworthy. I have a date with VicRoads on Wednesday
1965 Mk1 Cooper S Sprint/Hillclimb/Rally Car
2012 Land Rover Defender 90
PostPosted: Mon Jul 21, 2014 7:52 pm
Light clean on Dizzy, preparing for accuspark install.
and made my siggy
Nick
PostPosted: Mon Jul 21, 2014 9:09 pm
paid a vist to MSCN for some bling
PostPosted: Tue Jul 22, 2014 7:58 pm
Placed a order and deposit for carbon fibre parts to carbon weezel
Clubman bonnet
Double skin boot
Radiator fan
Radiator bracket
Hopefully l will see it in 6 weeks
Nearly finished building my rotisserie and made a engine lifting bracket thanks to the ausmini how to guides. :)
1993 R32 Nissan Skyline GTR
Users browsing this forum: No registered users and 116 guests
