It is currently Tue Jul 22, 2025 5:10 am
 Post subject: Tyre Recommendation
PostPosted: Wed Jun 04, 2014 4:39 pm
Hi Guys
I'm thinking of ordering a set of these bad boys soon
http://www.midlandwheels.com/Shop/P-238 ... Metal.html
I was just wondering what people would recommend for a 6x10" rim? brand/size
James
 Post subject: Re: Tyre Recommendation
PostPosted: Wed Jun 04, 2014 5:30 pm
Yokohama A008s if it's a daily driver, Yokohama A032R if it's a weekend warrior.
Forget Falken FK07Es, they don't grip as well in wet OR dry.
[edit] There are few other choices in 165/70-10 size now.
Bridgestones are no longer available.
Dunlop Formula Rs may still be about, but they wear pretty fast like the A032Rs do.
Last edited by drmini in aust on Thu Jun 05, 2014 7:51 am, edited 1 time in total.
PostPosted: Wed Jun 04, 2014 6:35 pm
So I'm assuming the A032R's will grip better but not last quite as long?
James
PostPosted: Wed Jun 04, 2014 7:00 pm
Yes, that is correct. They also need more negative camber for best performance. I would not fit A032Rs with standard front suspension, you need adjustable bottom arms and tie bars.
PostPosted: Wed Jun 04, 2014 7:26 pm
Oh I see, in that case I might go with the A008s. I don't thrash her so they should suit me fine. :)
Thanks for your help!
PostPosted: Thu Jun 05, 2014 7:44 am
I've got the faulkens on my mini came with them when I brought it... Can't wait till they wear out so can take them off and get A032Rs... I don't drive the car in the rain seeing its a weekend toy but going around a round a bout in the wet I come out 4 wheel sliding. Fun at times but gets you thinking how bad they are..
How much is postage for the 4 wheels from the UK??
64' 850 1275cc
PostPosted: Thu Jun 05, 2014 10:46 am
I had 30 year old cross plys on my first mini, I replaced them with Falkens.
The cross plys were better.
A008's are what I buy.
I bought a set of four 10x5's with A008s from Midlands:
$991 landed
Make sure you check Midlands have stock before you buy. When I bought my wheels 3 weeks ago, all they had were BRMs and Rosepetals left.
You're so square
Baby I don't care
PostPosted: Fri Jun 06, 2014 8:33 pm
I believe Bob Jane has a special on Yoko A008s at the moment - 4 for price of 3 = $105 each ($150 approx normal).
I have a set on my Mini k and they are excellent for daily driving.
PostPosted: Sat Jun 07, 2014 11:21 am
Yeah saw that on TV last night - Seems like a convenient sale for me :D
PostPosted: Sat Jun 07, 2014 12:39 pm
Just ordered a set of A008s - should last me a long time......and save a few bucks!
Saw a set of them on original 6" Mambas and the sidewalls stick much less than the Falkens I have on the front at the moment......sweet.
Cooper S Mk2
Cooper S Mk1
PostPosted: Sat Jun 07, 2014 12:46 pm
Only in the larger diameters! I have a set of 12 inch Dunlop Formula R's on my Clubbie and I love the look of them, unfortunately they need replacing and I can't get them any more :(
PostPosted: Sat Jun 07, 2014 1:00 pm
Stuckeys still list D93Js in 10"-
http://www.stuckey.com.au/tyres_details ... eName=D93J
PostPosted: Wed Jun 11, 2014 5:47 pm
I also just ordered a set of Yokohama A008's from Gordon Levin in Emu Plains for $139 each but you only pay for three so it was $417 for the set, fitted and balanced.
They are happy to fit them to my Cooper S wheels without tubes even though they are not Safety rims.
PostPosted: Wed Jun 11, 2014 6:37 pm
The 10x4.5s are not safety rims, because the tyre beads would break on a wheel this small. Folks in USA regularly break beads when fitting to these wheels.
Tubes in tubeless tyres are more trouble than they are worth. If you put them in Yoko A008s they chafe on the internal ribbing, and blow.
As I found out.
Subsequently I never managed to roll a tubeless Yoko off a 10x5 Contessa wheel at Wakefield Pk enough to lose pressure, and I did try pretty hard.
PostPosted: Thu Jun 12, 2014 6:21 am
That seriously sux.
