It is currently Mon Aug 18, 2025 1:17 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Wed May 28, 2014 5:52 pm
I found this on The Mini Forum . I always forget it, so I thought it would be a good reminder. :)
Here's the whole post.
"As this crops up so much here is the excellent picture showing the firing order and the direction of rotation of the distributor and the lead location.
When correctly timed on No 1 cylinder TDC (both valves closed) on the firing stroke the rotor arm will be pointing at the no 1 lead position on the distributor cap
Picture posted by Yoda TMF."
Dusk Blue
1964 850
PostPosted: Wed May 28, 2014 7:15 pm
I'll drop this into the How-To.
Sometimes you need a sanity check, and I have found myself looking for the firing order in the specifications...
The No.1 is situated at 2 o'clock, which is also important for initial distributor installation to get the vacuum advance pointing in the right direction, and again a sanity check reference when you pull all the leads off.
Users browsing this forum: No registered users and 70 guests
