It is currently Sun Jul 20, 2025 7:41 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 451, 452, 453, 454, 455, 456, 457 ... 568  Next
PostPosted: Sun Mar 30, 2014 8:55 pm
ah cool if you get more then some scratches and skin off the knuckles, you'll be in good hands.
PostPosted: Sun Mar 30, 2014 9:30 pm
looks like a nice ride M8, does the car have a tow bar?
It's easy once you know how.
PostPosted: Thu Apr 03, 2014 4:36 pm
Had a closer look at the passenger side a panel. Thought I saw a bubble so pulled off the covering strip and found a bit of a sus area on the front wing. Decided to take both front wings off and inspect the a panels really carefully.
PostPosted: Fri Apr 04, 2014 7:00 pm
Changed the oil and filter
Filled it with valvoline classic oil 3 bottles left might get more when i see it at 9.99 again like last year when i got it
PostPosted: Fri Apr 04, 2014 7:02 pm
Pulled off the front valance and found rust hiding under the strip that holds the bumper on. Glad I found it now...
PostPosted: Fri Apr 04, 2014 9:52 pm
Removed the windscreen from the 997 so I could start repairing the paint around the seams. The seams are fine, but the car had something poured on it in another life which has affected the paint below the drain holes.
I managed to crack the windscreen! Not unexpected. There was a large star crack where a rock had taken it out, and the crack radiated from there. I have another two windscreens as backup 8)
I'm really taking care of two issues...
PostPosted: Fri Apr 04, 2014 9:58 pm
Before removing or fitting laminated windscreens park the car in the sun to warm the glass. (yeah, I know!)
PostPosted: Fri Apr 04, 2014 10:06 pm
Yeah, it was laminated too... one of those windscreens with the tint along the top.
I think deep inside I wanted it to crack so I wouldn't feel compelled to stow it....
PostPosted: Sat Apr 05, 2014 10:05 am
as I think it is running better went and filled the fuel Tank, the gauge only reads half?
better go for a cruise and find some bumps.
PostPosted: Sat Apr 05, 2014 1:50 pm
Milatsmadmini
drove him, came home, washed and polished, then did the same in the engine bay :)
PostPosted: Sat Apr 05, 2014 5:50 pm
Decided to check why my front wheels bind when rotated by hand, I think the bearings may have been overtightened, so re tensioned. Finally fitted my replacement drivers window regulator and it works a treat, bit of a fiddly job getting regulator and window in right position.
PostPosted: Sat Apr 05, 2014 5:57 pm
Assembled the right hand front wheel bearing and hub, fixed up the driveshaft coupling on the left hand side. Changed the bearing on the front left too, bled the front brakes, replaced the brake shoes, adjusted up and did a few quick laps of the block!
PostPosted: Sat Apr 05, 2014 9:06 pm
Brakes are on , tomorrow l will bleed them, then off to get a wheel alignment
1993 R32 Nissan Skyline GTR
PostPosted: Sat Apr 05, 2014 9:26 pm
Brakes are always too shiney to put wheels onto, and then splash through puddles and cover in road grime...
PostPosted: Sat Apr 05, 2014 9:34 pm
Yer very true mick, cleanest they will ever be ha
