It is currently Mon Jul 21, 2025 3:27 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 448, 449, 450, 451, 452, 453, 454 ... 568  Next
PostPosted: Sat Mar 15, 2014 6:25 pm
Replaced my boot seal. The new one is much thicker then the old one and the boot lid sticks out a bit. I'm hoping it will sink in with time.
PostPosted: Sat Mar 15, 2014 6:59 pm
is it a seal on the body of the car?
if so, I had persuade the lip in a few places in order to get the boot to close properly...
1975 Hairy Lime/White Clubby
PostPosted: Sat Mar 15, 2014 7:59 pm
It will. Takes a little while. You won't need to lean on it. Its a good thing it still latches.
PostPosted: Sat Mar 15, 2014 9:28 pm
Some of these seals are bloody hard- I bought 3 from different places before I found a soft enough one.
Minisport SA's was softest, I think Kc and Mini King have similar now.
Here's what to look for- http://minisport.com.au/prod505.htm
[edit] stuff using those bloody clips, I used Selleys Kwik Grip contact adhesive instead. Hey it's a bitsa so who cares.... :lol:
Last edited by drmini in aust on Sun Mar 16, 2014 6:58 am, edited 1 time in total.
PostPosted: Sat Mar 15, 2014 10:22 pm
I used double sided tape to put my boot rubber on stuff using the 20 something clips they tell you to get
PostPosted: Sun Mar 16, 2014 12:53 am
Repaired al the headlight system. Turned out to be faulty hi low dimmer switch and faulty headlight switch. Fitted relays to headlights and tidied up all the engine and under dash wiring.
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Sun Mar 16, 2014 8:18 am
Thanks for the info. I just checked and I have the original soft one, but I clipped the lip onto the lip of the boot opening. Maybe that's the problem?
PostPosted: Sun Mar 16, 2014 9:21 am
Rovers etc had the seal on the body but it's a different design seal.
PostPosted: Sun Mar 16, 2014 4:05 pm
Last coat of varnish yesterday, glove box lid, speakers and head unit cage attached and stereo wiring installed and checked. Now to figure out how to attach my new dash! :)
'77 Leyland Mini Van
PostPosted: Sun Mar 16, 2014 5:36 pm
rust... all rust :(
PostPosted: Sun Mar 16, 2014 7:01 pm
Coat of paint on the engine.
Metallic Ford Blue Print.
Now to put the chrome on/
PostPosted: Sun Mar 16, 2014 10:01 pm
Replaced the LH steering rack boot today. Easy job.
Then switched over the front shocks to gas.
Car now rides pretty sweet. Just need to get around to switching over the back ones as well.
Alec
PostPosted: Sun Mar 16, 2014 10:15 pm
Locked up all four wheels, smoked up the tyres and left my mark on the Great Eastern Highway! I wasn't paying attention and didn't see the light turn red! Ooops......
PostPosted: Sun Mar 16, 2014 10:19 pm
Bugger. Lucky there wasnt a car in front of you
Minis..
1975 van
PostPosted: Mon Mar 17, 2014 4:20 pm
I did that the other day, although it was a surprise new round-a-bout on the top of a blind hill!
Users browsing this forum: kirby and 75 guests
