It is currently Sun Jul 20, 2025 3:53 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 447, 448, 449, 450, 451, 452, 453 ... 568  Next
PostPosted: Mon Mar 10, 2014 9:03 pm
Prepped and primered the roof for the last time. Sat in the shed with the radio on sucking back a coldy wishing I lived on a big property so I could keep working into the night.... damn neighbors with their new born. ...
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Tue Mar 11, 2014 10:30 am
Bled my clutch & put shiny new stickers on the doors so it goes faster. Stickers are from 'I Say Ding Dong'. Looks like a rally car now!
After the hassles with the clutch master cylinder not priming, I'm not looking forward to bleeding the brakes.
Continued working on the aero blanking plate under the engine bay & measured the ground clearance of the air-dam so I can adjust it to match the ground clearance of the sub-frame. Measured & marked the rear wing end-plates for trimming to ensure the're road legal. Sat on my huge veranda overlooking my big property & enjoyed the birdsong. Wished the mozzies would go away though. >:S
1.8L Sunshine - Legal, legit & lovinit
PostPosted: Tue Mar 11, 2014 12:06 pm
Milatsmadmini
replaced bottom of steering rack bolt thingy as the last one had sheared after over tightening... (or it were a crappy bolt...) then tightened up the U bolts amazing how direct the steering feels once more :P
I too have an annoying oil leak... i suspect tappet cover as well... hmmmm
PostPosted: Tue Mar 11, 2014 11:23 pm
Burnt out 1x headlight switch, 1x hi low beam dimmer and half the wiring to the headlights... time to uogsde the electrical system me thinks. Should have really done it when I upgraded to halogen lights.
Minis..
1975 van
PostPosted: Wed Mar 12, 2014 6:38 am
What a bugger :(
"64 Smooth Roof Van (Colin)
PostPosted: Wed Mar 12, 2014 3:24 pm
Finished making my `bush version' of the outrigger bearing ring removal tool. It works too.
Pics and details tomorrow... :wink:
[edit] Pics and details are now up, see separate thread.
Last edited by drmini in aust on Thu Mar 13, 2014 12:57 pm, edited 1 time in total.
PostPosted: Wed Mar 12, 2014 9:32 pm
I was at a local bearing and seal shop and found some seals similar to the banjo seals in the SU electric fuel pump so I brought them to give them a try, replaced the seals plumbed it up outside the vehicle and powered it up... hhhmmm no luck they are still leaking I think I'll have to wait for karcraft to get them back in stock in 6 weeks as other local shops that have them are charging silly prices for postage for 3 little seals that fit in a standard envelope.
On the plus side it gave me an excuse to start it again, my wife thinks the engine sounds to big for a mini, my exhaust finishes at the extractors.
PostPosted: Thu Mar 13, 2014 7:58 pm
After two years of sitting looking at my 76 Clubbie sat under a tarp on my driveway I finally got it uncovered and mounted on a rotisserie, ready to start attacking the rust.
Wish me luck...
PostPosted: Thu Mar 13, 2014 10:37 pm
Wish me luck...
No such thing as luck, all the best :wink:
Wish me luck...
PostPosted: Thu Mar 13, 2014 10:59 pm
Try mg spares at smithfield nsw or http://www.sumidel.com/contact_us.html also in nsw
PostPosted: Thu Mar 13, 2014 11:35 pm
sand blasted the inside of the tail gate and sanded the out side after discovering a large amount of body filler. anyway stuck with the sanding and was pleasantly surprised to find no rust, just a bad filler job to cover an dent. happy with that.
PostPosted: Fri Mar 14, 2014 8:04 am
Thanks I'll check them out.
Phoned them they had some, so I brought them, postage still cost more then the bits though.......
PostPosted: Fri Mar 14, 2014 5:10 pm
dropped it off at the painters to get some love...
I dont like oil leaks
PostPosted: Sat Mar 15, 2014 8:24 am
Received a package from karcraft, gotta love new bits!
Gave my clutch master the once over and replaced the slave with a new one, bleed and flushed the system, I now have a moving clutch. My pedal is heavy though, I think the hose might failed internally, might be time to replace the hose.
Users browsing this forum: fuzzy-hair-man and 72 guests
