It is currently Mon Aug 18, 2025 1:12 am
Post new topic Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24, 25, 26 ... 29  Next
PostPosted: Fri Jul 05, 2013 7:25 pm
That's huge!how many litres is it? I was thinking of something like this which would take up the whole boot floor almost but could be covered and retain some space. I was just a bit worried about rear impact but I guess a std tank is right against the back panel anyway!Image
Potato
PostPosted: Fri Jul 05, 2013 7:44 pm
Not sure how big it is yet, might measure it up tomorrow if I remember
Life's a garden.... Dig It!
PostPosted: Wed Jul 10, 2013 4:54 pm
Not a massive update but my trigger wheel arrived so after trying to figure a way to mount it decided to make a home made lathe and machine the outer pulley until it was a press fit with the trigger wheel,
Result being this. Now all il do is position it, double check its correct with the trigger sensor, and weld it on with a couple of stitches.
I've got my shielded cable now too so I can press on with the ignition system!
Potato
PostPosted: Fri Jul 12, 2013 8:21 am
Nice job there, should work just fine
PostPosted: Fri Jul 12, 2013 9:44 pm
Gordo wrote:
It was in the car when I got it, good possibility it was built by Mr Enforcer
Planning for the apocalypse? That's sure is a lot of fuel.
PostPosted: Sat Jul 13, 2013 4:36 pm
Mine is -
555 long
335 high
350 wide at bottom
210 wide at top
PostPosted: Sat Jul 13, 2013 5:06 pm
Cheers for that, will give me some comparable measurements
Here's today's efforts
Got my order of fuel related gear from jegs, new regulator fittings and these cool hard line fittings so I don't have to use hose clamps!
Also finished wiring this in, including setting up the trigger wheel
All of this resulted in this :) runs like a bag of sh!t of course because I need to tune it, also had no exhaust on so it sounded like the death of the world but I, so happy it's all working!
http://img.photobucket.com/albums/v734/ ... 5DB9B2.mp4
Good day it was!
Potato
PostPosted: Sat Jul 13, 2013 7:57 pm
Also, does anyone know what each of the alternator terminals are? Trying to wire it into a mini loom
Potato
PostPosted: Fri Jul 19, 2013 8:28 pm
Alternator wired up
Potato
PostPosted: Fri Jul 19, 2013 9:47 pm
Glad you got it sorted.
Looks neat.
PostPosted: Wed Jul 31, 2013 6:00 pm
Got my fuel cell and started setting it up in the boot, it's 50 odd litres so that will be plenty!
New fuel pump
Also got some piper cross filter socks for the ram tubes
And turns out the rover mpi throttle cable is perfect for the bike carbs! Pedal travel is about 2 inches so may need to adjust the pedal pick up point but meh..
And here's a video of it running on the std megajolt tune, idles un assisted now! Won't do any more until the fuel system is plumbed in correctly but I'm so happy it's running
Potato
PostPosted: Wed Sep 18, 2013 12:20 pm
Good on ya sean, impressive!
How is it running now?
1963 850 - laid up
PostPosted: Sun Oct 06, 2013 11:57 am
Literally Havnt touched the car since July.. Funds are too tight, welder has broken down and I can't afford to fix it etc... Business is slow. Disappointing too I miss working on it..
Not sure when I will be able to continue.
Potato
PostPosted: Sun Oct 06, 2013 3:55 pm
Hang in there mate.
All the best with it, keen to see this finished and back on the road.
Grant
100% Pure A Series Turbo
PostPosted: Tue Oct 08, 2013 6:50 am
Yes mate, keep your chin up, yu ou will be back into it soon!!
Tricky
Users browsing this forum: Google [Bot] and 194 guests
