It is currently Fri Jun 20, 2025 5:14 pm
PostPosted: Sun Sep 15, 2013 11:25 am
Hi all
I am looking at buying a new MINI preferably 2007 onwards and was just wondering what faults they have and what is a good price to pay for a 2007 onwards MINI I am in South Australia
Thanks
Present
- 1968 Morris Mini Deluxe- resto
-1979 Leyland Moke
-2007 R56 MINI Cooper
Past
-1964 Morris Mini Van
-1965 Morris Mini Van
-1961 Morris Mini 850
PostPosted: Fri Sep 20, 2013 9:28 pm
Go a R53... But better, Supercharger Whine... Having owned a R50, R53, R56. I have just bought a fully loaded R53 Works
PostPosted: Fri Sep 20, 2013 9:58 pm
Fully loaded R53 works is where its at for sure 8)
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Sat Sep 21, 2013 12:56 pm
Am I allowed to drive an r53 works on my p plates
And is there any major difference between the Cooper and the Ray
Present
-1979 Leyland Moke
Past
PostPosted: Sat Sep 21, 2013 1:10 pm
In most states, forced induction (in general) is not permitted with Ps - you will need to look at power to weight ratio restrictions.
MINI Ray is a down spec Cooper - both power and trim.
PostPosted: Sat Sep 21, 2013 4:43 pm
Mini Ray = Mini One
PostPosted: Sat Sep 21, 2013 5:14 pm
Are the mini rays any good in reliably wise
Present
-1979 Leyland Moke
Past
PostPosted: Sun Sep 22, 2013 10:24 pm
No different than a Cooper, Just I believe less goodies, and different engine maping
PostPosted: Mon Sep 23, 2013 6:05 pm
Does this different engine mapping have any change on the reliably of the eyoungine
Present
-1979 Leyland Moke
Past
PostPosted: Mon Sep 23, 2013 6:36 pm
No. I think it will give u less power. But jump on www.mini.com
PostPosted: Mon Sep 23, 2013 7:22 pm
Do would the $20000 mark be about right for a 2007 > present
Present
-1979 Leyland Moke
Past
PostPosted: Mon Sep 23, 2013 8:59 pm
$29K on the road vs spending $20k- $25k on a 2nd hand one?? I would go new...
PostPosted: Mon Sep 23, 2013 9:08 pm
I've got a 2011 R56 Mini Ray. Its a great car. Mines a 6 speed manual it has 75kw but loads of torque which makes it very drivable its pretty damn effortless. A drive in the hills and your holding it back. Just in case you're wondering my other car is a Mitsubishi 380 with 175kw. The Mini has BMW reliability. Saying that mine had a new gearbox at 5000km. I lost 1st gear then it came back but second went, then 3rd went and came back. Apparently BMW had a dodgy batch of Gatag 6sp manuals, they changed mine without even questioning.
Build quality is great. We had a Mitsubishi Lancer as a hire car and one as a loan car whilst the 380 was being serviced both were brand new and the difference between the 2 was chalk and cheese, the Lancer was awful when compared to the Mini.
But there is no room in the back. My 2 kids just about get in the back.
The difference in power between the Ray and Cooper is down to the mapping of the ECU. The throttle doesn't open 100% on the Ray hence its reduction in overall power, apart from that the engines are exactly the same. Spec wise you can order one with almost whatever you like, bearing in mind it is a base model.
New they were $28880 but were reduced to $24880 some time later, not sure what they are now. So I recon you should pickup a fairly new one for around $20000.
I have no regrets in buying mine I would recommend the 6sp manual any day. The only thing I chose when buying was black painted Cooper wheels, which is an Adelaide Motors BMW option only. not a BMW Australia option.
Hope this helps.
TOO MANY MINIS AND NOT ENOUGH TIME
PostPosted: Mon Sep 23, 2013 10:59 pm
Id double check if you can. I imagine you could get an exemption in nsw and qld with the power to weight. Check out mini mods for more info only thing ive heard about the later turbo models is getting the intake checked as the plastic goes brittle and can brake into the turbo and its about $2k to fix but ive only read about it on mini mods never met anyone its happened too in person
Sent from my GT-I9505 using Tapatalk 4
PostPosted: Fri Sep 27, 2013 9:00 am
So is this there any major engine or transmission problems that I should avoid
Present
-1979 Leyland Moke
Past
