It is currently Thu Jun 27, 2024 12:35 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Jun 30, 2004 4:20 pm
its called flashlube...about $15 for a big bottle and you can get it at places like supercheap etc.
PostPosted: Wed Jun 30, 2004 4:21 pm
Flashlube. I got it last time at AutoBarn. $16/L. Repco have it on special this month for around $12/L if you're quick.
Cap on the 1L bottle holds 7.5mL, so 1 capful does 7 or 8L of unleaded..
PostPosted: Wed Jun 30, 2004 4:28 pm
thommo09 wrote:
ooo ooo!!! SHOTGUN!!
i want it when ur finished with it kev!...please? :D
hey i;m probably wrong, but arent drums able to stop better than discs (with race compond hoes, braided hoses etc) anyway? i know that discs stop straight and stop better once the drums start to fade, but i thought that drums could stop better in a single go......get me?
Drums are just no good for competition use.
[<edit> welll... nowhere near as good as discs, anyway.]
If you put hard compounds linings in (which are probably unobtainium now) they won't work when cold, and they will still suffer from drum distortion and heat soak when hot. Can't cool the buggers properly....
Remember the early Bathurst races- the Dodge Phoenix, Studebaker Lark etc V8s ran away at the start for a few laps, then their drum brakes got hot and that was it.
PostPosted: Wed Jun 30, 2004 6:19 pm
Ok sweet. I'm glad a lot of people recommend the 1100.
A different view to the other few people that don't like them.
I will have a look at it on friday. Anything to look for while its in the donor car?
And will i have any issues with changing the Engine Number over to the 1100 one... im in SA.
PostPosted: Wed Jun 30, 2004 7:32 pm
hey will i wouldnt worry too much about the different engine number....i mean my clubby has a reco replacement engine and i'm pretty sure the engine number on the rego hasn't been changed
so you know....
PostPosted: Wed Jun 30, 2004 7:40 pm
Yeah right. I will probably end up changing the engine number to the 1100 one coz i can. The 1275 does worry me, only because of the discs and the fact that i cannot get it on the rego without keeping the 998 number and if i need to claim on my insurance, im ****ed basically.
PostPosted: Wed Jun 30, 2004 7:43 pm
I had some grief after I put a recond 1100 into our `78 Clubbie (which had a `99H' series 998 motor) and took it down to the blueslip garage to do the right thing..
Basically the so-called `inspector' said the motor was too old- it was out of a `73? Clubbie. I told him the blocks were the same but he refused to listen. Anyhow I took it away in disgust and kept driving.
Stupid thing is, I could have put all the 1098 bits into the original 998 block instead of this 1100 one, and not had a problem. So beware... :?
PostPosted: Wed Jun 30, 2004 7:47 pm
Ok but if i do have troubles, what is to stop me getting it checked at a different place.
I am sure regency wont pick up on anything like that.
Theyre a bunch of faggots but they do know what they are looking at.
And if they dont, they just call someone who does. :roll:
PostPosted: Wed Jun 30, 2004 7:58 pm
What they are on about I think is compliance with ADRs. I believe you can put a newer motor into a car (with its relevant emission gear) but they can get upset if you fit an older one.
I do know of a `78 Clubbie that had a MK1 S motor put in, and a Weber, so yeah- it pays to go to an inspection station that is less than zealous about ADRs. Wouldn't want to refit the air pump, gulp valve and all the other crap, would we.. :lol:
PostPosted: Wed Jun 30, 2004 8:03 pm
this is sa we're talking about. lol :wink:
they're the slackest state in the country on cars.
PostPosted: Thu Jul 01, 2004 9:04 am
Kev, is this because your replacement motor didn't have any of the motor retarding gear, such as air pump, for post '76 vehicles?
On a similar note, years ago I bought a dirt cheap 1981 Commo that had a stroked 308 with corvette box. This thing went like an absolute demon, but could not be registered, because the 308 was pre pollution gear crap (RTA said it came from an HQ Holden). So....me sold the motor and box, which ended up paying for the car, so I got a free 1981 V8 Commodore, into which I slotted the right motor :D
Took it to Bathurst in '93 to see the Tooheys 1000....ah those were the days..... :wink:
PostPosted: Thu Jul 01, 2004 9:59 am
850pvan: amen, brutha
:wink:
PostPosted: Thu Jul 01, 2004 2:54 pm
like i said....dont worry about it....she'll be right! :D
PostPosted: Thu Jul 01, 2004 7:14 pm
This `78 car had been initially registered the year before, without all the air pump etc crap, no problem- they just looked at the 99H engine number and it was sweet.
It's unregistered at the moment- I'm going to a different station this time, if they ping me one of 2 things will happen:
1. I'll pull it apart, bore the original 99H (998) block, and load exactly all the 1132 bits from this 1100 block into it. or....
2. A 99H engine number might just happen to appear on this block by magic..... :x
PostPosted: Thu Jul 01, 2004 7:30 pm
Had similar hassles with my 82 Gemini years ago.
When I was in NSW I built up a worked 2litre Jackaroo motor with weber, ported early 1600 head, mild cam extractors etc. I didn't change the engine number, and the 1600 and 2000 blocks are pretty much identical externally. So it passed the yearly pink slip without a problem.
When I moved to VIC I had to get a roadworthy before I could register the car. If failed on lack of pollution gear. So I fitted the standard 2000 head with air pump, EGR, standard carb etc. Mind you, every hose was blocked with a ball bearing and the air pump did not have any vanes in it! :lol: It passed.
But then I had hassles with VicRoads who said it was not legal with the 2000cc engine and demanded and engineers certificate. Finally I managed to convince them that it was legal as the 2000 was an option in Japan and it bolted straight in. They checked on the computer and found they already had nine Geminis registered with a 2000cc engine. So I finally got it registered.
Not long after I sold the car. I sold the head, cam and carby in the Trading Post. That old Gemini is still running around Geelong with blocked off pollution gear!
The laws have since changed - if you already owned the car interstate, you don't need a roadworthy when you register it in VIC. And of course there is no annual roadworthy either. :D
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
