It is currently Mon Jul 21, 2025 10:25 pm
 Post subject: Gearbox Linkages
PostPosted: Fri Aug 31, 2012 7:40 pm
Evening All,
I just wanted to see if anyone had pics of the end on the gearbox that the gear stick connects to.
I have two and a half gearboxes in the shed and the magic wand from my 850 will work in any of them.
Have I been lucky enough to subconsciously collect the boxes or is the tail used for a couple of different gear changes?
Ian
1961 Morris 850 (being restored)
1965 Austin 1800 (daily driver)
PostPosted: Sat Sep 01, 2012 7:36 pm
Dumb question then hey?
PostPosted: Sat Sep 01, 2012 8:29 pm
this will help you identify the parts for remote change
http://www.heritagegarage.com/-/catalog/gearbox/25.htm
and this is the read diff casing the remote change bolts too
http://www.heritagegarage.com/-/catalog/gearbox/7.htm
1969 Blue Mini K, 1330cc, Weber 45, polished aluminum roll cage, Race seats, 4 point harness, full rewire incorporating 8 fuses, 6 relays and new headlights :) just needs tyres front shocks and a windscreen til re-register
PostPosted: Sat Sep 01, 2012 8:42 pm
The 850 shift was only used on the 850 and the early Moke in Aus.
The Cooper, Deluxe, Cooper S, K and Clubman used the remote shift.
Leyland Minis used the rod-change (well they used the remote shift for a bit first)
Mokes and Mini 1100 vans (aka K Vans) used the remote box with a direct shift) till the rod change took over.
Take a look at page 2 in this thread to see the photos of some of the different types of shifts..
PostPosted: Sun Sep 02, 2012 9:09 am
The Mini King
Spot on Again
I would just add that the gearlever used on Mokes and Mini 1100 vans (aka K Vans) used the remote box with a direct shift) till the rod change took over.
Had the slot on the top of the ball not on the side like the 850, however the 850 stick can be modified for use in above
PostPosted: Tue Sep 04, 2012 12:34 pm
Hi All,
Thanks for that.
So I'm guessing the boxes are quite different where the gear stick goes in.
That means I have some how collected two magic wand gear boxes.
Ian
