It is currently Thu Jul 31, 2025 4:24 am
Post new topic Reply to topic  [ 73 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu Aug 30, 2012 11:20 pm
not sure what that movie is? what's it about i could just not remember the name
Regards Kermit (TadPole)
PostPosted: Fri Aug 31, 2012 7:39 am
sgc wrote:
nobody sees you. You have to drive with the expectation that the people around you are going to do something stupid, because they will. Give yourself an escape route at all times - know without looking that you can change lanes in a hurry when the truck you're passing pulls into your lane to squish you.
That's some pretty good advice there, I have to say though, I've ALWAYS driven like this, even when I was driving Vans (merc Sprinters, Iveco Daily's) because people just DON'T pay attention anymore. I've had someone almost take their mirror to the side of one of the vans before I hit the horn because I assumed they'd see me before getting that close.
Kermit wrote:
Yeah you have a point, they would more than likely look for a truck.
I have been checking out some horns on ebay, their are some that are like 110 decibels that just look like standard horns. he had a vid of them and the noise was incredible and they were pretty reasonably priced too. I think for around 30-40 + postage. the one that is in it at the moment isn't loud at all. kind of sounds like a fart that some one is trying to hold in lol. thank you for the advice though will definately keep that in mind.
I've got a Stebel 134db horn, like this one http://www.youtube.com/watch?v=tDyq6tPYyPg
in my current car and I have to say, it WORKS! When I've had to use it, it's worked fairly well and most people either freeze mid -stupid/dangerous act- or they swerve back to where they were, although I have been forced onto the median strip once (due to the wally behind the guy coming across that forced himself beside before the lane change was complete :shock: ) I originally bought it for the mini builds but wanted to try it out.... now the Mrs wants one, and the new car's getting one.. I think the mini will be getting two though. just for added safety.
So what's the last thing you remember...
I'm pretty sure you were..
WRONG ANSWER!!!
PostPosted: Fri Aug 31, 2012 9:34 am
that's a pretty loud horn lol. does it run off air or electric?
PostPosted: Fri Aug 31, 2012 10:10 am
it's an 'Air horn' ..... from the site:
" The Stebel Compact truck Horn does not require complex connections to the vehicle's compressed air chamber because it features an incoporated mini-compressor with a totally independent capability. Particularly suited for mountings "under the hood" .
Homologated CEE ECE and Electromagnetic Compatibility."
Site link: http://www.stebel.it/stebel2012/products.asp?IDserie=17&uso=1&tipologia=pickup
but it's pretty much a mini air tank / compressor on the side of a 'snail' horn, hooking it up was (for me) just a wire from the battery to an inline fuse, from that to a relay [relay has one positive from the battery, one positive to the horn, one line directly from the button in the car and one earth to the chassis.] , from there to the horn, then from the horn an earth to the chassis. Easy.
WRONG ANSWER!!!
PostPosted: Fri Aug 31, 2012 10:57 am
I can vouch for the stebel, it's fantastic. It's not a low note, so people don't go looking for a truck when it sounds, and it's loud!
PostPosted: Fri Aug 31, 2012 2:38 pm
the video was awesome, im definately going to check it out cheers :)
PostPosted: Fri Aug 31, 2012 2:45 pm
This, or if there's another cheaper, comes with all you need :D
http://www.ebay.com.au/itm/Stebel-Nautilus-Compact-Truck-Car-Air-Horn-12volt-300Hz-Deep-110Db-Wiring-Kit-/130754515159?pt=AU_Car_Parts_Accessories&hash=item1e719390d7
WRONG ANSWER!!!
PostPosted: Fri Aug 31, 2012 3:12 pm
I have a Nautilus, lets just say if they can't see me they will definitely hear me!
I drove mine daily for 2 years, sure it was only a few short KMs but Lillee is as reliable as the Mrs' Corolla...
Lillee - 1969 Morris Mini K
PostPosted: Fri Aug 31, 2012 4:24 pm
cheers for the link, got it in my watch list now. just have to wait till i have some funds to purchase one :)
PostPosted: Sat Sep 01, 2012 2:10 pm
started the mini today, been a little while since I started it cos it had a buggered battery. took a bit to start but once it started and warmed up was all good :)
PostPosted: Sat Sep 01, 2012 10:00 pm
I've been doing some research in to the horns we've been discussing the last couple of days and i stumbled upon these. Would these be better than the other model or about the same?
http://www.ebay.com.au/itm/Loud-Stebel- ... 5d34ca9454
PostPosted: Sat Sep 01, 2012 10:02 pm
they're a higher note, it's up to you... i'll find the link for you. brb
I think these are the ones.. there's an audio clip at the bottom of the page. http://www.stebel.it/stebel2012/products.asp?IDserie=3&uso=1&IDprodotto=15&tipologia=auto
WRONG ANSWER!!!
PostPosted: Sat Sep 01, 2012 10:51 pm
I think out of the 2 of them I would prefer the twin ones, cos it's more of a car sounds just bloody loud lol.
PostPosted: Sat Sep 01, 2012 10:53 pm
Edit: stupidity......
WRONG ANSWER!!!
PostPosted: Sat Sep 01, 2012 11:01 pm
I'm not sure i follow?
Users browsing this forum: No registered users and 72 guests
