It is currently Fri Jun 27, 2025 11:39 am
 Post subject: 123 ignition settings
PostPosted: Mon Dec 12, 2011 8:20 pm
Hi guys , i'm nearly finished putting my 1186 motor together , i'm going to use a 123 distributor but was wondering if anyone has any ideas on what setting to start off on as the paperwork only really covers standard motors . My specs are 1186 (+100 GR pistons) , 295 head fully ported , piper 270 cam , 11-1 compression , twin 1 1/4 su's . Due to the high compression i guess the settings will be pretty critical so does anyone have any ideas please .
PostPosted: Tue Dec 13, 2011 5:33 am
Well I can't help, but I do hope you get some informed answers to this thread because this one never came up with the goods.
PostPosted: Tue Dec 13, 2011 10:17 am
This space for rent
I'll have a crack.. I have one in my car -- 1152, ported '295 head, unknown but lumpy cam, LCBs, 2x HS2's, 10:1 compression.
I don't have the 123 manual in front of me, but the way I set up mine was to firstly choose the group of four curves most appropriate to my engine using the manual as a guide. From memory it was numbers 5-8, but I could be wrong there.
Once you've chosen the curve group, start with the least aggressive advance (lowest number), static time the dizzy, then go for a drive. Put some load on the engine at ~ 2000rpm in top gear and listen for pinging -- if it doesn't ping, try the next curve up (more advance). If it pings, you've got too much advance and you should back off to the one lower.
You should be able to feel the difference between curve groups in the seat of your pants, the throttle response will be better in the correct group and it'll develop more torque at lower revs. Once all the advance is in at revs, they'll all feel the same.
Hope that helps! :)
PostPosted: Wed Dec 14, 2011 3:51 pm
My motor is 1330cc
GR 282 cam
lightened ,balanced blah blah blah ...
i use a 123 dizzy on setting number 3 that gives me 28 degrees of total advance ..
http://www.tdcperformance.ca/pdfs/123Mini-28.pdf
and this is how to set it up ..
http://www.tdcperformance.ca/tuning_guide.htm
enjoy
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Wed Dec 14, 2011 4:02 pm
My motor is 1330cc
GR 282 cam
enjoy
Beanie
HOTBRICKS
'65 NCF MINI.....
