It is currently Tue Jun 24, 2025 5:22 am
Post new topic Reply to topic  [ 210 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 14  Next
PostPosted: Tue Dec 06, 2011 12:00 am
blue_deluxe wrote:
...me and a mate .... was going to buy a suzuki cappucino and put a hayabusa in it. Til he remembered he was 6'6 and 100kg.
Youtube Hayabusa Cappucino Donnington Park. Man that thing goes well and in the 7 minutes of vid the driver doesn't look to be "fighting" it at all. It looks well sorted.
PostPosted: Tue Dec 06, 2011 7:36 am
Link JC...?
PostPosted: Tue Dec 06, 2011 9:39 am
http://www.youtube.com/watch?v=LNgfUxbyNUU
This one?
You're so square
Baby I don't care
PostPosted: Tue Dec 06, 2011 12:06 pm
This one?
How awesome is that? Imagine that punting around lakeside?
PostPosted: Tue Dec 06, 2011 2:07 pm
For interest only.. Not really that keen on flatshifting...
https://shop.pingelonline.com/iwwidb.pv ... t?comp=PEI
http://www.flatshifter.com/flat-shifter-max/
PostPosted: Tue Dec 06, 2011 2:11 pm
Air filter..
http://www.merlinmotorsport.co.uk/ITG-A ... index.html
PostPosted: Tue Dec 06, 2011 4:08 pm
JC wrote:
Would work well with paddles and let you keep both hands on the wheel!!
PostPosted: Tue Dec 06, 2011 7:48 pm
hey in the "coffee-busa" vid,,, there`s a porsche at about 2min30 that has some serious boogy & gets away from the little capachino quicksmart, then he pulls into the pits... but the little cappachino sure looks lik it`s whoopin eveyone elses Ar$e good & proper :-)
JC wrote:
This one?
Man he aced everything except the GT2, even an XTR which is no mean feat!!
I like it.
PostPosted: Tue Dec 06, 2011 7:53 pm
& it looks like it handles like my buggy,,, just doin it easy with no nervousness ;-) Nice
PostPosted: Tue Dec 06, 2011 11:41 pm
http://club-s12.org/v3/index.php?topic=13822.0
PostPosted: Wed Dec 07, 2011 10:16 am
JC,
Have you decided on the architecture yet???
Are we talking longitudinally, front mounted engine and RWD???
PostPosted: Wed Dec 07, 2011 12:36 pm
Archangel007 wrote:
JC,
Yep. That's the plan. If I had a rear subframe here or even just the trailing arms I could get my neighbour here to build the custom rear arms for me.
Though I am torn. I'm contemplating a mini tech style frame that utilizes all the gtir upper a lower control arms and that would enable the use of the hubs.
That would only then require shortening the shafts to the correct length then make the frame using the mini subfrane to car mounting position, the gtir diff mounts and gtir suspension arms.
The downside to that is that it is very unlikely that I could use a 10" wheel, which I want to do.
It's in my head, I'll try and draw it.
PostPosted: Wed Dec 07, 2011 1:28 pm
So these are the options Ive come up with. If anyone has some alternatives please contribute. I am not an engineer, I just like visualising things.
Option 1
This retains the majority of the factory gtir components.
Option 2
This "looks and acts" like a mini subframe that houses the diff. The custom components are the trailing arm/hub/brake mount and the cradle that locates/positions the diff.
The benefit of this option is that the trailing arm is custom made so that the wheel retains its factory position in the wheel weel (centered on the wheel well, up and down movement of the shock is in line with how its meant to be). Im concerned with utilising the factory gtir suspension that the bottom arm that mounts to the hub and goes forward to the front of the cradle may protude beyond the "opening" in the boot floor for the mini subframe.
Edit:
Actually, I've never thought about this before but wouldn't the fact mounting of the rear trailer arm cuase the wheel to move on a "pivot"? I mean as the wheel rises and falls it swings on a curved plan rather than straight up and down. That would have to mess with suspension geometry wouldn't it?
PostPosted: Wed Dec 07, 2011 2:12 pm
Is that Josh selling this?
http://www.ebay.com.au/itm/Nissan-GTIR-diff-and-cradle-assembly-RNN14-/250946422421?pt=AU_Car_Parts_Accessories&hash=item3a6d928695
