It is currently Sun Jun 29, 2025 1:27 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Apr 21, 2005 5:15 pm
I'l just have to check what I have Now :shock:
PostPosted: Thu Apr 21, 2005 6:02 pm
"My race mini saw 9000rpms quite regularly at speedway from about 1982 to about 1988, that`s a lot of revs , for a long time, in a very hard yakka type of racing, nearly every saturday nite, then it did a number of years on the race circuits up here, Lakeside, Morgan pk, Willowbank etc including all the hillclimbs & autocrosses that i do & then it hit Targa Tasmania for 2002"
wow you used one race mini for all of these events? Hmmmm???
PostPosted: Thu Apr 21, 2005 6:44 pm
i have a steel one on the way its 11lbs but i don't no what that is in Kgs. just need to be shipped
FOR SALE MInidlx, 1293, GR head, RE-13, GR worked Redline Manifold, 45 mm DCOE,pulsar dizzy , "S" Disc's, Mk II "S" box, 3.65 diff. Minator 10X6's On the loose
PostPosted: Thu Apr 21, 2005 7:02 pm
its basically 5 kg and thats damn light man :D
hope be back on the road soon with a blown 1275.
PostPosted: Thu Apr 21, 2005 7:13 pm
OK guys, I weighed a standard (later 1 piece) flywheel today and it is 7.6kgs with straps on.
Standard backplate was about 2.8kg.
Not sure how accurate these scales are but I'll check weights again tomorrow on my bathroom scales- also I'll dig out a standard 2 piece one and weigh it.
<EDIT> These weights are crap, I don't trust the scales- see my later post below.
BTW, Russell Engineering lighten them the same way I do, either 1 piece or the later 2 piece. Then he puts holes in 'em.. if it's for a racer.8)
I've never seen one go bang! either, but I won't lighten them if they have been bashed with hammers etc.
Last edited by drmini in aust on Fri Apr 22, 2005 10:27 am, edited 2 times in total.
PostPosted: Thu Apr 21, 2005 7:42 pm
Yeah the one that we have that has marks from being bashed with a hammer is scary :shock: Can't imagine that will ever do 9000rpm :lol:
Lillee - 1969 Morris Mini K
PostPosted: Thu Apr 21, 2005 7:48 pm
Rupert,,,sorry for mis-leading you,
what i meant to say is,,,that the same """Engine""" that came out of the speedway car went into the circuit car & yes,,, for all those events :-)
 Post subject: Ring Gear
PostPosted: Thu Apr 21, 2005 9:38 pm
BTW, Russell Engineering lighten them the same way I do, either 1 piece or the later 2 piece. Then he puts holes in 'em.. if it's for a racer.8) I've never seen one go bang! either, but I won't lighten them if they have been bashed with hammers etc.
Doc, do you know if anyone does anything special about Ring Gears?
I have heard of one popping off and just wondered whether anyone puts a spot or two of weld or some sort of drill and tap clamping arrangement after sweating the things on????????
 Post subject: Re: Ring Gear
PostPosted: Thu Apr 21, 2005 9:45 pm
Mick,
Ring gears are indeed tack welded, on Mini AUTOMATICS. Not a great idea to tack weld to grey cast iron flywheels though, it doesn't exactly help the metallurgy... but I once saw one done. Not pretty.. :cry:
My theory is the ring gear is a bloody good interference fit, and will never come loose, as long as you don't go mad milling and drilling through the flywheel, which can negate the original interference fit.. :wink:
PostPosted: Thu Apr 21, 2005 10:11 pm
Well theres a clue...this happened on a race Mini...
which could well have had "mad milling and drilling through the flywheel, which can negate the original interference fit" :?
PostPosted: Fri Apr 22, 2005 10:25 am
OK I've weighed these again.. on my bathroom scales. I trust them more than the POS ones at work.
Lightened (turned) 2 piece flywheel with 1/2" ring gear, no straps on = 5.4Kg
Standard 1 piece flywheel with 3/8" ring gear & straps on = 7.4Kg
Standard Oz backplate = 3.0Kg.
Can't find a stocko 2 pc flywheel- I've lightened `em all! :cry:
So I reckon Chong's flywheel has had around 2Kg off it. :wink:
PostPosted: Fri Apr 22, 2005 10:36 am
2kg! that's still heaps! :lol:
I was expecting 500grams or 1kg off at best! Sweet as Kev! 8)
PostPosted: Fri Apr 22, 2005 11:37 am
Also have to remember that weighing the flywheel only gives a rough comparison. Depends where the mass is... thats why some companies do the integral ring gear ultralites which eliminates the extra material for the ring gear to sit on on the conventional type.
PostPosted: Fri Apr 22, 2005 1:24 pm
Most I take off the outside.
Vizard says you can reduce it on the engine side too, I don't bother- this is light enough for a road car, IMO. :wink:
PostPosted: Fri Apr 22, 2005 5:41 pm
Why did they have the two different sized ring gears? It would seem a good move to fit the 3/8 one if you want a light flywheel but then again they would probably wear out quicker :?:
