It is currently Mon Jun 23, 2025 12:54 pm
Post new topic Reply to topic  [ 210 posts ]  Go to page 1, 2, 3, 4, 5 ... 14  Next
 Post subject: Bike Conversion
PostPosted: Sat Nov 19, 2011 5:14 am
I'm thinking I might use Ausmini as a tool to record my shopping list for my next car... I seem to move house, lose hardrives, change employers, move countries and the only thing that remains constant is access to the ausmini database... so here goes.
So I know its a forum, but I'm being selfish as this is really the only part of the forum I look in.
Shell (Morris) - Simple paint/interior. As light as possible.
Pulsar GTIR rear cradle & tailshaft (supports N/S engine configuration). Either this or buy a set of the Z cars rear control arms and fabricate a craddle that holds a diff and locates control arms (diff mount/driveshafts etc). The second option would be preferable as the gtir rear end means new a new fuel tank and compicated suspension set up.
Big bike motor (pref carb fed to simplify fuel/wiring set up). Consider clutch set up to take additional weight (drag bikes).
Engine to be located in standard mini subframe.
Exhaust (simple enough). Room for turbo?
Cooling (mini radiator in situ)
Bike instrument cluster. (http://www.bikersdiscountstore.co.uk/sp ... -pd-18.php)
Shifter (simple cable arrangement) (http://www.pro-motive.co.uk/resources/_ ... rstick.jpg)
Investigate the impact of changing the driven wheels to the rear. If not possible, buy the promotive kit.
PostPosted: Sat Nov 19, 2011 6:11 am
Hi JC,
Sounds great, and cant wait for you to start...
Is this for when you return to Gods Own??
Tricky
PostPosted: Sat Nov 19, 2011 6:20 am
The other motor I,ve seen considered is the K3-VE used by Daihatsu and Toyota 1.3LTR 16valve DVVT 86HP at 6,000rpm 120Nm at 4,400rpm
The earlier versions were oversquare but the later versions had a longer stroke for more low down torque , with the variable valve timing they increased the compression ratio to 10:1 , you could be lucky enough to find a 4 speed sequential gearbox out of a Copen
PostPosted: Sat Nov 19, 2011 7:57 am
Archangel007 wrote:
Hi JC,
Tricky
Yep, back in June '12 with a container load of gear. I'm contemplating selling the chopper in favour of buying the minitec Honda kit too. The chopper just seems complicated and obnoxius (befitting of my character)
PostPosted: Sat Nov 19, 2011 8:02 am
Adapt the Z cars kit to fit something like this....
http://www.superfastminis.com/REAR_FRAME.htm
PostPosted: Sat Nov 19, 2011 8:14 am
Resources
http://www.zcars.org.uk/onlineshop.php
http://www.superfastminis.com/ALL%20PRODUCTS.htm
PostPosted: Sat Nov 19, 2011 8:46 am
GTIR Diff craddle. Note inclusion of handebrake cables....
PostPosted: Sat Nov 19, 2011 9:50 am
That looks heavy. For real lightness have a look at the bottom of this page:
http://www.force-racing.co.uk/rear-suspension/
PostPosted: Sat Nov 19, 2011 10:56 am
Yeah I had anticipated making a jig off the factory arms and cutting down/using the factory subframe like that shown above. 950 pounds is pretty **** exspensive for what it is really.
PostPosted: Sat Nov 19, 2011 12:18 pm
PostPosted: Sat Nov 19, 2011 9:34 pm
You might have to manufacture the rear end JC if its going to be AWD...
Will you have any room left in the container for some bits n pieces???
PostPosted: Sun Nov 20, 2011 8:29 am
What do you mean by manufacture? There's the minitech option shown above that for $3k will be a fairly simple arrangement to fit (just need a new boot floor).
Should have some room, what are you thinking of sending over?
PostPosted: Sun Nov 20, 2011 10:18 am
http://www.ebay.co.uk/itm/Chain-drive-D ... 19caf582b9
PostPosted: Sun Nov 20, 2011 5:41 pm
hijacking here....what about an mx5/miata rear end?
PostPosted: Sun Nov 20, 2011 8:42 pm
JC wrote:
http://www.ebay.co.uk/itm/Chain-drive-Diff-not-Quaife-Trike-Kitcar-Buggy-Mini-not-LSD-Differential-/110779269817?pt=UK_CartsParts_Vehicles_ATVQuad_Trike_Parts_Accessories_SM&hash=item19caf582b9
That might work, but you still may have to manufacture the cradle that mounts the suspension arms etc - unless of course you buy the MiniTech option.
Supercharger for the Y-Block, some Effie sheetmetal...
