It is currently Sat Jun 28, 2025 12:54 pm
PostPosted: Thu Jun 30, 2011 11:57 am
It's time to look at replacing my extractors on the 1275. I currently have rubbish Perry-style 3-1 extractors that are starting to leak out the centre pipe.
Engine is a worked 1360, 286 cam, ported head, dell'orto. But I'm trying to tune it for good mid range rather than top end, so have leaned to the smaller size on carburettor chokes etc. So far so good, the engine goes hard :wink:
So in keeping with this, I was considering fitting the Maniflow freeflow extractors instead of the more common LCB. I've always found LCBs a PITA anyway....
Just like to know if anybody is running this setup on a worked 1275, and whether you'd recommend it!
Bear in mind anything I fit will be an improvement over what I've currently got :wink:
PostPosted: Thu Jun 30, 2011 12:03 pm
yes we have fitted plenty of these, but i`m affraid to say that i havn`t done any specific "back-to-back" dyno testing to see conclusively any differences between the 2 types
but i am a fan of them for mildly worked 1275-1360s for road use, no problems at all
PostPosted: Thu Jun 30, 2011 12:08 pm
Ultimate hp isn't that important - this is a budget performance engine, using a combination of components based on what trick bits I had lying around!
Sounds like I'll give them a go. Is it likely to be a problem that the 1275 is higher than the small bore motors?
PostPosted: Thu Jun 30, 2011 12:21 pm
no i havn`t found any dramas fitting them, the height (so far) hasn`t been a problem & we`ve fitted quite a few (maybe 5 sets so far)
& i`m a fan of them """Because""" they seem to help the lower & mid-range power spread,,, so yeah i`m a fan of them for road cars
PostPosted: Thu Jun 30, 2011 12:39 pm
Thanks Matt, that's exactly what I want to hear!
PostPosted: Thu Jun 30, 2011 12:52 pm
Mods rock!
I've fitted a heap of them too. Usually go straight on, but the last set needed so heat, wasn't set right. Work well, that's true but in all fairness, I seriously doubt you'd even be able to measure any HP benifit from these over most others on the market.
One thing I don't like about them is they can be a bugger to get apart, but that's true of most exhausts. The Perry with slip joint I do like for that reason, but you have to be sure your engine steadys and mounts are always in tip top condition.
Just also make sure that the flange thickness closely matches that of your inlet manifold too.
PostPosted: Thu Jun 30, 2011 2:11 pm
Maniflow freeflows tend to crack at the top Y connection, more so on rodchange boxes due their poorer location.
I've seen a few do this. Make sure both your steady bars and rubbers are in good condition.
PostPosted: Thu Jun 30, 2011 2:14 pm
If I end up having to get the exhaust welded/modified to fit the extractors, should I look at fitting a flex pipe?
PostPosted: Thu Jun 30, 2011 4:02 pm
I fitted maniflow LCB to my last mini the freeflow are probably for a smaller capacity engine , I had trouble with my maniflows as the flanges that attach to the head were not flat check them before you fit them .
PostPosted: Fri Jul 01, 2011 7:19 am
Same here, I had to grind the centre flange flat on both my Maniflows. They burn gaskets if you don't.
Hate to say it, but the Chinese Maniflow copies seem better made.. :shock:
