It is currently Tue Jul 01, 2025 12:15 am
 Post subject: Re83 Cam charged
PostPosted: Thu Apr 07, 2011 8:40 pm
hey is anyone running this N/A & charged.
what diff,, how do you think it is for everyday???
is it lumpy? hard in traffic?
PostPosted: Thu Apr 07, 2011 9:07 pm
I have an RE83T cam sitting in my new engine.
Sorry no help at this stage and at the speed I am moving I think I am a few months away from driving the car
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Apr 07, 2011 9:09 pm
ok cool what boost are you running & diff ratio?
PostPosted: Thu Apr 07, 2011 9:18 pm
Hi nick
I have a VMAXSCART kit to bolt on and the choice of a 2.9:1 or 3.1:1 diff
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Thu Apr 07, 2011 9:30 pm
ok great. i'm going to run 3.1 in mine.
my cam right now is rubbish has nothing.
PostPosted: Thu Apr 07, 2011 10:26 pm
What do you mean by rubbish?
I have another GR cam in my Cooper S which has no Power below 2500rpm and is great around 4500. :)
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Thu Apr 07, 2011 10:29 pm
And I have yet another GR cam in my 1360 which lights the tyres at 5000 and spins em to 8000... 8)
Note both the RE83 and RE13T cams has a greater LCA angle for turbo and S/C use, this is so you don't blow all the fuel mix out the exhaust due to too much valve overlap. This makes it feel soft without any boost, compared to the regular RE83 and RE13.
[edit] oops like michaelb I assumed you had an RE13T in it already!!!
Your later post says otherwise...:oops:
Last edited by drmini in aust on Fri Apr 08, 2011 9:09 pm, edited 1 time in total.
PostPosted: Thu Apr 07, 2011 10:33 pm
It's very very mild close to a stock it's a A+ cam mild as
Nothing like a cooper s cam
PostPosted: Thu Apr 07, 2011 10:37 pm
What size rockers are you running? 1:3?
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Thu Apr 07, 2011 11:08 pm
Yep 1.3
PostPosted: Fri Apr 08, 2011 3:54 pm
Have a look on the Wade cam website- they have some real good cam profiles and it only cost $120 inc postage for them to do a grind. the 240 profile is a real good one.
PostPosted: Fri Apr 08, 2011 4:20 pm
going to go for the Re83 it's will be good for my set up.
PostPosted: Sat Apr 09, 2011 2:11 am
Whats the deal with the RE83T? hotter than the 13T?
any hints to specifically whats different?
PostPosted: Sat Apr 09, 2011 11:39 am
Have you tried calling the man himself and asking him??
Lillee - 1969 Morris Mini K
PostPosted: Sat Apr 09, 2011 6:43 pm
Supercharged
it might be a bit expensive to call from the UK, not to mention calling at the correct time?
Users browsing this forum: No registered users and 42 guests
