It is currently Mon Jul 28, 2025 8:22 pm
 Post subject: wiring loom differences
PostPosted: Mon Jan 24, 2011 1:41 pm
ahoy there chaps and chapettes
I'm in the process of fixing up my melted wiring and ive noticed on ebay a 78 moke wiring loom. How different would it be to a 1973 clubman loom? I dont need a complete loom just probably a 1/4 of a front one. The wire lengths and colours would be similar wouldnt they?
or does anyone have a spare clubby one they want to sell me
thanks
trent
PostPosted: Mon Jan 24, 2011 1:50 pm
Moke would be considerably different I'd have though.
Follows a different path around the car so why waste the time?
I'd try and find a clubby one, or even an 80s rover one will fit.
:D
PostPosted: Mon Jan 24, 2011 1:59 pm
The biggest difference is likely o be with the wiper motor wiring. Mokes around that era used a complicated system to get two speeds. Otherwise they should be similar, same colours and approximate location of components, but not a direct swap.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Mon Jan 24, 2011 2:14 pm
The lengths of the wire runs would be all over the place. It would be a case of chopping and changing to get things to fit.
The speedo wiring alone is very different.
Get a proper one or fix yours.
PostPosted: Mon Jan 24, 2011 2:16 pm
Instruments part is completely different too. Different plugs and wires. You could adapt a Moke one, but it's a lot of work.
Someone on here must have a clubby one available. I have one from a 71 Clubby povo pack, but I think I ratted bits from it for my Moke so it's probably no good to you.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Mon Jan 24, 2011 2:18 pm
well thats the reason i come to this site, i learn things!
thanks dudes
PostPosted: Mon Jan 24, 2011 7:55 pm
Lash out and buy a new one! :D Yes it will cost about $500, but at least you will have no dramas for the next 20 years!!
Thats what I am doing!
PostPosted: Tue Jan 25, 2011 6:44 pm
...and it wont have been made by Lucas if you get a locally manufactured one.
PostPosted: Tue Jan 25, 2011 6:57 pm
about to strip out a deceased 78 van any use to you?
PostPosted: Tue Jan 25, 2011 7:02 pm
The 78 should have some extra not needed bits (brake warning light, Handbrake light etc), but the rest should work.
Dicko
PostPosted: Tue Jan 25, 2011 10:02 pm
have a 76 one somewhere :)
PostPosted: Tue Jan 25, 2011 10:11 pm
is the 76 a van too? what price would you be after??
PostPosted: Wed Jan 26, 2011 6:34 am
was a sedan
$20 ?
PostPosted: Wed Jan 26, 2011 9:00 am
P.M. sent frednutz&co
