It is currently Mon Jul 28, 2025 5:31 am
 Post subject: cracked subframe
PostPosted: Sat Jan 22, 2011 9:52 pm
ok guys i pulled my front subframe out about a month or 2 ago because the tower was cracked, and put in another good 2nd hand one.
i lifted up bonnet the other day to c that this one is cracked in the same spot. now i have springs in it instead of rubber donuts could they be doing this ???????? .
PostPosted: Sat Jan 22, 2011 9:57 pm
Did the new one go in easy enough?
PostPosted: Sat Jan 22, 2011 10:00 pm
yer no worries at all y
PostPosted: Sat Jan 22, 2011 10:11 pm
No twist in your body.
Did you have the springs in the old frame?
yer and it cracked in the same spot
PostPosted: Sun Jan 23, 2011 3:21 am
Mods rock!
Go back to the rubber donuts. The springs are bottoming out. They do not have or allow the same travel as the donuts do.
Or you can set your Hilo's lower - much lower. Don't try to set them near stock height.
PostPosted: Sun Jan 23, 2011 9:14 am
I find it very hard to believe that springs are the couse of that.
Including myself, lots of people are running spring set up for a lond time no issues regarding hight or bottiming it out.
If anything; I find my spring setup much more comfortable.
Anyways back to original issue; Is your front hight very low?
If yes that might create some space when the front airborn, and when lands on the road creats big impact. (when I say airborn I do not mean like the movies just when the pressure is of the suspension.
Just an idea.
Since light travels faster than sound, people appear bright until you hear them speak
PostPosted: Sun Jan 23, 2011 9:25 am
If the suspension is very low, then the impact will be absorbed by the rubber bump stops.
If each subframe has lasted 40 years in original configuration, only then to be cracked in a very short time, then yes it would be worth looking very closely at the new springs.
That's not to say you can't perform a little welding to reinforce as well as repair the towers. Its cheaper than swapping everything out.
PostPosted: Sun Jan 23, 2011 8:37 pm
NAV-MAN
Is this where it cracked?
PostPosted: Sun Jan 23, 2011 9:13 pm
i stitch weld them around the top caps (where they`re cracking) & then strap them-->
IE: weld straps of metal along the top & bend them down the sides of the towers & then weld them down the sides as well (ala rally mini subframes)
Job done, no more worries
PostPosted: Sun Jan 23, 2011 9:44 pm
Welding around the top edge should cure the cracking but I would chuck the springs and refit the donuts, I agree with the others when they say it sound as if the springs are bottoming out.
Matt the Mini man has suggested this, adding the extra steel I would only do if you plan to jump the thing over railway lines :lol:
Have a Nice Day.
PostPosted: Sun Jan 23, 2011 10:59 pm
were it cracks is were the bolts come screw into the edge of that like were it rises up to the bolts it cracks
PostPosted: Mon Jan 24, 2011 7:44 am
Come again?
PostPosted: Mon Jan 24, 2011 9:51 am
Hanra wrote:
Come again?
He means it cracks where the bolts come out of the tower. There is a risen up diamond shaped piece. Its cracked here.
PostPosted: Mon Jan 24, 2011 10:42 am
You have got the spacers fitted? I've seen them missing on cars before.
I race my mini and haven't managed to crack the subframe yet!
Users browsing this forum: Bing [Bot] and 77 guests
