It is currently Fri Aug 01, 2025 4:34 pm
 Post subject: Ignition Light
PostPosted: Mon Jan 17, 2011 11:02 am
Hi all.
I hopped in the car this morning and the ignition light is staying on. As I rev it, it get fainter but is still on. Now I checked the output voltage at the altenator and it reads 15.4V at idle. When I check the voltage at the battery at idle it is 12.5V.
I have been having trouble as the battery keeps draining on me.
What is wrong?
What can I check?
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Mon Jan 17, 2011 11:41 am
you had this problem when we had the national park drive didnt you?
have you checked the earths?
possibly dud regulator?
PostPosted: Mon Jan 17, 2011 11:44 am
The National park cruise was just a loose wire. I'm thinking dud reg too. Might take the alt out and take it over to the auto electricians.
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Mon Jan 17, 2011 11:45 am
It just seems weird that I have good voltage out at the alt but no where else.
I have check all the wires for continuity but they are all good.
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Mon Jan 17, 2011 11:54 am
Mods rock!
Sounds like you could have an open circuit diode in your rectifer pack and with the battery draining, possibly another that is crook.
PostPosted: Mon Jan 17, 2011 12:13 pm
the alt is out, just need to take it to the auto electrician to have a look see. Its times like these I wish I had a second car (well third car).
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Mon Jan 17, 2011 12:19 pm
Thanks GT,
Will let you know how I get on.
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Mon Jan 17, 2011 1:57 pm
Mods rock!
Could one of your fellow 'Gong Mini members lend you an Alternator until you get yours sorted? Surely someone nearby has one lying about.
FYI, 1300 / 1600 Fort Escort & Cortina use the same Alternator (same mounts)
PostPosted: Mon Jan 17, 2011 2:06 pm
This space for rent
That would be my guess too.. been down this road before ;)
PostPosted: Mon Jan 17, 2011 2:16 pm
Mods rock!
Just got me thinking.
Ryan, Have you got a decent soldering iron around 50 to 60 Watt?
My guess here is, rather than an actual failed diode, a poor or broken soldered joint.
Exactly what model alternator do you have?
PostPosted: Mon Jan 17, 2011 2:22 pm
[quote="GT mowog"]Could one of your fellow 'Gong Mini members lend you an Alternator until you get yours sorted? Surely someone nearby has one lying about. [\quote]
i have one but it was slowly dying when i took it out 9 months ago.
borrow the one of andys old motor?
PostPosted: Mon Jan 17, 2011 2:30 pm
I don't really need the car. I have the gf's car tomorrow anyway to give it a service and take it for pinkslip. I just needed a car to get the alt to the auto sparky, so I rang my mum (good lady).
Should be ready tomorrow arvo I hope.
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Mon Jan 17, 2011 2:33 pm
I'm actually a little concerned about your 15.4V out - that's a little high. It might damage the battery over time. So it could possibly be something with the regulator.
PostPosted: Mon Jan 17, 2011 2:35 pm
It may also damage some electrical items.
Check the boot to see if the battery has been boiling and if it has clean it up!
PostPosted: Mon Jan 17, 2011 2:37 pm
Yes, thanks for your concern. I too was worried about the high volts. The battery water was very low when I checked it this morning.
It should all be sorted by the auto electrician.
Ryan Filippi
Minis In The Gong
[email protected]
