It is currently Tue Jun 24, 2025 8:20 pm
 Post subject: 4efte using 10"
PostPosted: Fri Jul 23, 2010 7:00 am
Hi Mates
im finishing my conversion and i want to keep the 10" wheels, anyone is using this wheels on a 4EFTE Mini?
PostPosted: Fri Jul 23, 2010 8:55 am
I believe MiniMad just went back to 10's in his 4EFTE and loves it compared to the previous 12's...
1972 Leyland Clubman, 4EFTE 1330cc Turbo, 220Hp on 17psi
(1/4 mile: 13.8s @108mph @168Hp)
PostPosted: Fri Jul 23, 2010 9:45 am
Yea as Ray said, i'm running 10x6 with my conversion now.
I think you will need to look at your local laws to determine whether you can do it. I'm running 7.5" vented/slotted/drilled discs with alloy 4pot calipers and so far so good.
PostPosted: Fri Jul 23, 2010 9:52 am
Hi Mini Mad, sorry to hijack but are you using a brake booster?
2008 Prado GXL
PostPosted: Fri Jul 23, 2010 10:37 am
No booster
PostPosted: Sat Jul 24, 2010 1:11 pm
thanks for the reply!
i´m using split rims 10x7" and KAD 4 pots 7.9" vented
PostPosted: Sat Jul 24, 2010 7:49 pm
what benefits have you noticed as youve been loving it ?
PostPosted: Sat Jul 24, 2010 10:44 pm
Its my own personal preference, I've tried all 10s 12s and 13s, and going from 13s to 10s there is a lot of weight savings in unsprung weight, less torque steer, less/no bump steer, more traction, Overall better handling but brakes are the compromise for this.
PostPosted: Sun Jul 25, 2010 3:06 pm
thanks, can you upload a pic of your Mini with 10"?
PostPosted: Sun Jul 25, 2010 9:01 pm
You must be kidding right - its a Mini with 10's FFS
DOZ
PostPosted: Sun Jul 25, 2010 9:56 pm
DOZ
lol - good point....
what brake / wheel combination did you end up with Josh?
PostPosted: Mon Jul 26, 2010 4:52 am
DOZ
but its to check how low is
PostPosted: Mon Jul 26, 2010 10:50 am
clubman S wrote:
DOZ
the actual height of the car is basically the same when going from 13" to 10" wheels, because the tyre size goes up - there might be 5mm height difference for the car
here's a chunky looking clubman on 10"s I pulled out of a topic in the Members Gallery
PostPosted: Mon Jul 26, 2010 10:59 am
simon k wrote:
clubman S wrote:
DOZ
jajajaj thats my clubby mate :D
PostPosted: Mon Jul 26, 2010 11:31 am
clubman S wrote:
simon k wrote:
clubman S wrote:
DOZ
lol - well you know what it looks like then :D :oops: nice looking car ;)
seriously, it won't sit much higher on 13" wheels, if you want to run 10"s and need it further off the ground, just adjust your hilo's a bit
cars with 13" wheels usually sit higher because they need to adjust the hilo's up so the wheels clear the mudguards at the front, because they're usually very wide, and a really wide offset - part of the "look" people want with 13" wheels. Doesn't do it for me, I like 10"s - look better, cheaper and handle better
