It is currently Sat Jun 28, 2025 2:21 am
 Post subject: Morris 1500
PostPosted: Thu Feb 11, 2010 11:54 am
Has anyone tried to put a Morris 1500 engine and gearbox into a mini. Does it fit or not?. What about the 5 speed gearbox - will it bolt to a mini block?
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
PostPosted: Thu Feb 11, 2010 2:59 pm
M1500 into a Mini has been done.
No, the box won't fit a Mini block, the size and layout is different. I had a gearcase here, it's now in the skip at work.
WTF would you get parts for a M1500, they are an orphan these days. :?
<edt> Shameless plug- I do have 2 NEW M1500 8.4" disc rotors if anybody?? needs some. Real cheap.:lol:
Nooooooooo, they won't fit Mini drive flanges.
Last edited by drmini in aust on Thu Feb 11, 2010 6:05 pm, edited 2 times in total.
PostPosted: Thu Feb 11, 2010 4:28 pm
My cylinder head man, Rob, raced a mini years ago with a Morris 1500 engine, gearbox etc in it, with some sucess.
Have a Nice Day.
 Post subject: Re: Morris 1500
PostPosted: Thu Feb 11, 2010 6:35 pm
there is someone who apparently has converted a few mini gearboxes to run that gearset
I'd like to have a go at it
PostPosted: Thu Feb 11, 2010 6:46 pm
Mods rock!
Robin in the MOA (Vic) put one in his Moke (with a 5 speed). It went OK, got airbourne quite easily (on the sand dunes), but at the end of the day, it really was no better than a standard 1275 and used a lot more fuel. Sorry, good thought but not worth bothering with.
Terry Pollard now has this Moke.
PostPosted: Fri Feb 12, 2010 12:44 am
don`t mean to be picky Doc, but they`re actually 8.3" rotors :-)
PostPosted: Fri Feb 12, 2010 6:01 am
Mods rock!
picky, picky :lol:
PostPosted: Fri Feb 12, 2010 8:48 am
What he said ^^
Matt you are a Picky Person.. :P
PostPosted: Fri Feb 12, 2010 10:44 am
yeah ok i`m picky, sorry :-)
can`t help it
it`s just in my nature
i won`t say anymore about it now
you won`t hear a peep from me
i`ll keep my mouth shut
my fingers won`t type anymore
i`ll just be quiet
won`t say a word
not even a peep
you won`t hear a thing
i`ll be quiet as a mouse(pad)
quiet
nothing
zip
zilch
i won`t say anything else
nothing
i`ll just sit here & won`t make a sound
ill be a good boy & just be quiet
no more nonsense
no more picking
no more typing
nothing
i`ll just shut up
shhhhh
you won`t hear a word from me
i promise
nothing
won`t say a thing
Shhhhh
ok?
alright then, that`s it
nothing
OK???
no more picking
Nothing
i`ll just be alll shhhhh
ok?
see,,,
Nothing
havn`t said a thing
PostPosted: Fri Feb 12, 2010 2:00 pm
Mods rock!
OK...that's good now...nice an quiet..zzzzzzzzz :roll: :roll: :wink:
PostPosted: Fri Feb 12, 2010 3:48 pm
As far as I recall the 1500 engine (O series?) was just a heap of crud.
PostPosted: Fri Feb 12, 2010 4:25 pm
Its not a "O" series , its an "E" series and they are quite good engines, there smooth and respond well to "tuning" My 1750 powered Marina go's very well, any Austin Kimberly or Tasman with the 6 cylinder version of the E series are great and the "big block" 2.6lt fitted to Marinas and the P76 are great little engines, as powerfull as an equivalent Holden or Ford engine. I am currently building a "hotted up" 6 for my P76 so ill post some photos soon. As for a 1500, there ok too but respond even better with a set of twin SUs and a 5 speed.
Have a Nice Day.
PostPosted: Fri Feb 12, 2010 4:44 pm
I have never owned an E series but I would not knock one back if it was offered. My wife's grandfather had a P76 Six and it was a very smooth engine.
My question to the experts is can you fit a 1750 crank in a 1500 motor?
PostPosted: Fri Feb 12, 2010 10:24 pm
Yes, if you have a early type 1750 crank. The later type had larger main bearing journals and wont fit into a 1500 or early 1750 block. - not sure about the flywheel end of the crank tho, 1500 cranks may be different, I havent seen inside a 1500 for a good 15 years. All i can remember about 1500s is the balk rings in the gearbox can be used in a mini box if you grind of the 3 extra lugs. Bore sizes for all the E engines are the same & pistons are NLA, except if you find NOS or get someone like JP to make them.
Have a Nice Day.
PostPosted: Sun Feb 14, 2010 12:39 pm
my two cents now....
one being is there much of a weight difference between E and A series
engines....
cause I thought about putting a MGB engine in (think b series)
and was told it weight as much if not more than the car :?
Users browsing this forum: No registered users and 25 guests
