It is currently Fri Jun 27, 2025 1:25 pm
 Post subject: Gears...
PostPosted: Thu Jun 03, 2004 9:34 pm
...tick knob. Can someone tell me the thread size on the clubman gear lever. I want to make a threaded insert for this nice leather thing i bought. I'd glue in a small tapped rod so i can screw it nice and tight... the self cutting plastic one it comes with turns round and round so easily.
If someone knows the size, i can whip one up tomorrow in metal work. 8)
Cheers.
PostPosted: Thu Jun 03, 2004 9:39 pm
If no one knows, go down to ya local nuts and bolts store with a standard knob, and try some bolts in it. ;)
PostPosted: Thu Jun 03, 2004 9:58 pm
Yep good idea 8) .
Pity theres no hardware stores open at 10pm and my range of assorted bolts is quite limited.
Anyone?
Will.
PostPosted: Thu Jun 03, 2004 10:15 pm
(guess...) 3/8" UNF?? :roll:
Try a Mini head nut if U got one spare...
<edit> Nope, I just looked at an old one- looks like 5/16" UNC or M8- bit hard to tell in the dark..
PostPosted: Thu Jun 03, 2004 10:37 pm
I've got a knob infront of me, it's definatly not a fine thread!
PostPosted: Fri Jun 04, 2004 10:04 am
make a sleeve and chuck a pointed grub screw in the side.
my g/f's gear knob is a solid stainless ball, and it hasnt moved since I put the pointed grub screw in it (threw away the one it came with)
...its leaking oil... and thats a good sign!
It lets me know that I havent run out yet. :P -Tzi 4-9-04
PostPosted: Fri Jun 04, 2004 10:59 pm
measure it? :?
Users browsing this forum: Bing [Bot], drmini in aust and 72 guests
