It is currently Thu Jun 26, 2025 9:13 pm
Post new topic Reply to topic  [ 133 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9  Next
PostPosted: Sun Aug 09, 2009 4:34 pm
spraycanmansam wrote:
awdmoke wrote:
Now I know it's not an A Series...
Out of curiosity 850's never even had a harmonic/torsional damper/balancer did they? Pretty sure I've got a block in the shed with just a steel pulley... in similar vein to awdmokes example, is there any comparisons of A series engines with no dampers vs dampers?
My 1961 twin carb 850 (OK, so it used to get a bit of a rev to 7000 sometimes) once tore the tin pulley apart through the rivets. But not long afterwards, the 850 crank broke, through the front web.... so I dunno which problem caused what.
Common 998s (non Cooper) had the plain tin pulley too... and there are still zillions running about. Ditto 948 Morris Minors.
PostPosted: Sun Aug 09, 2009 4:42 pm
There are also some cast iron front pulleys about,,, not tin riveted,,, not 2 piece rubber-ised , just plain std issue one piece non-dampened cast iron ones
PostPosted: Sun Aug 09, 2009 4:45 pm
Yep, the 998 Moke donk I sold recently had one of these on.
But note that plain pulleys were never used on either the 997, or 1275 (both long stroke) Mini cranks. These all had a `balancer' (better described as a `damper') :P
PostPosted: Sun Aug 09, 2009 4:58 pm
ha,,, this is both a funny thread & a very educational one at the same time
i was always led to believe that it was actually called a "Dampener"
& a "Damper" was a camp fire baked bread :-)
Maybe it`s because some "Dampeners" turn into "Damper" when they bust :-)
PostPosted: Sun Aug 09, 2009 5:00 pm
Were these single piece iron pulleys the same as the inners from the two piece Cooper S type?
A `dampener' would make the crank wet, not what you want/need... :lol:
Nope Mick, the later plain pulley wasn't the same as Mk1 S inner.
PostPosted: Sun Aug 09, 2009 5:04 pm
ha,,, see,,, this thread is both funny & edumacationable :-)
& no,,, "S" inner is "S" inner only,,,
the early cast pulleys were (i think) originally from spridgets/minors early era,,, just left over & used on early minis too,,, (((but i wasn`t in the factory at the time so could have been for any other reason))),,, just my guess after they realised the tin ones were breaking apart
PostPosted: Sun Aug 09, 2009 5:11 pm
Thanks, it was only because I spotted one in this ad on ebay. Sure looks like an S inner pulley to me...
For 6.05 at the moment, someone is going to be unhappy I put this here :)
http://cgi.ebay.com.au/Cooper-Leyland-M ... tsupported
PostPosted: Sun Aug 09, 2009 5:13 pm
BTW
Gratuitous ROMAC pictures for your pleasure, they are pretty aren't they when new?
This one's on Skender's new donk.
PostPosted: Sun Aug 09, 2009 7:04 pm
Mick wrote:
BTW
Mick is that the steel centre type or all alloy type......They do look awesome and a very good unit.
PostPosted: Sun Aug 09, 2009 7:27 pm
Steel I believe, Skender picked it up once it became apparent his original type was cactus.
PostPosted: Sun Aug 09, 2009 8:20 pm
Romac only do all steel or alloy with a steel centre, no such thing as an all alloy Romac HB
The alloy/steel units are fantastically light though compared to an "S" unit
PostPosted: Sun Aug 09, 2009 9:05 pm
I must have been misinformed then or they were misinformed and passed on the incorrect information. The first few I bought I was told that they were alloy centre and alloy weight/outter ring and when I picked it up it was very light and the metal finish looked much the same on both parts.
Anyways thats niether here nor there really, I think they are a really good product and will keep using them, especially on non standard engines.
PostPosted: Sun Aug 09, 2009 9:17 pm
yeah i bought some ages ago & they had all 3 avaliable at the time.
PostPosted: Mon Aug 10, 2009 12:16 am
Just a little thought on the lighter after market dampers. Does anyone have the specs on the rubber resiliance and the difference in weight of the outer section compared to the original ones. The after market ones might look pretty but do they really do the job as the BMC engineers originally designed.
I have found from doing torsional calcs that if the "resistance" of the damper is either too soft or too hard then you do not get the damping of the harmonics in the correct frequency range.
Just a mad idea,but if the rubber is stiffer then it may not work as well. Also if the mass of the outer weight is less then this could also cause problems.
A example of this was on a clatterpillar gen set. The damper was due for relpacement and the new one sent was a "new design" that cat's were using. The genset broke the rear torsional drive soon after. This was replaced and everyone thought all was OK. About 2 months later the crank broke. Scratch that V16. Ofcourse cat just fobbed it off, but the ship owners had a independant assesment done. It was found that the rubber material was of a different dimension and compound than the original unit.
The independant engineering company said after the testing that the new damper was not good enough to take out the torsional.
It's just a thing that I am aware of and maybe?????????
They can be checked by measureing the force required for the same amount of deflection [degrees or radians]
If a crank has a certain amount of stressing already and the damper is too stiff then this could also cause a crank breakage.
www.minisprintgt.com
