It is currently Fri Aug 01, 2025 12:08 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2, 3  Next
 Post subject: Electric Windows
PostPosted: Sat Jul 18, 2009 6:04 pm
Hi Forumites,
Installing new door cards in The Cat, and I just had a thought about installing electric windows befoe I drilled the hole for the winder handle.
Has anyone installed electric windows in their mini, and how hard was it?
Would appreciate any feedback regarding this.
Tricky
PostPosted: Sun Jul 19, 2009 7:24 am
Anybody??
PostPosted: Sun Jul 19, 2009 11:10 am
I have thought about it quite a lot.
The guys at turbominis do it and actually get a nett weight reduction, but that's on UK style doors.
PostPosted: Sun Jul 19, 2009 11:36 am
To do it in a clubby with the latter doors it is very easy to do with parts from wreckers not sure about early doors tho. I put them in my Mini when I first got it only took half a day to do.
My only problem is I don’t have limit switches so if you hold the button to long bad things happen :oops:
I’ll put pics up tonight after work.
Thanks Nathan.
PostPosted: Sun Jul 19, 2009 2:15 pm
Excellent Nathan, thanks for that.
AWDMoke - can you send me a linky??
PostPosted: Sun Jul 19, 2009 4:38 pm
can u put them in round nose doors ones with out lift up door handles ?
PostPosted: Sun Jul 19, 2009 6:11 pm
The only one that springs to mind is http://www.turbominis.co.uk/forums/index.php?p=vt&tid=181014
 Post subject: p windows
PostPosted: Mon Jul 20, 2009 4:47 pm
Hi I have done power window conversions on a few jap cars using Spal kits from AUDIOXTRA http://www.audioxtra.com.au/html/s01_home/home.asp
also made some to fit XW Falcon by mounting late model power windows out of an XF cut of the XF arms and welded on XW arms I have a bunch of switches left over form previous jobs if you need some Regards Daren
PostPosted: Mon Jul 20, 2009 5:38 pm
i'm interested in this to as i wont to do the same with my doors.
cheers dan
Cheers Dan
PostPosted: Mon Jul 20, 2009 7:42 pm
anybody put pop door latches and taken the handles off. Id be interested to see electric windows, and electric pop latches and all wired to an alarm, so you can hit your key chain and the door pops open.
Ive seen this on alot of cars, door panels that are flat, no handles, but would all that fit in a mini door.
PostPosted: Mon Jul 20, 2009 8:04 pm
It is illegal to have no door handles on a car so I have been told because in a emergency they can't open ya doors
PostPosted: Mon Jul 20, 2009 8:06 pm
All you need is a mechanical way to open the door. A switch somewhere makes it legal.
PostPosted: Tue Jul 21, 2009 8:42 am
Which is bullcrap because in a car accident or something chances are the power gets cut anyway.
PostPosted: Tue Jul 21, 2009 11:14 am
i was about to suggest someone make a conversion for sliding windows, but then i realised that would essentially end up with a set of hydraulic shears on each door. :P
so i'll leave you with this...
http://www.youtube.com/watch?v=GOFoE3EzE-8
PostPosted: Tue Jul 21, 2009 11:32 am
I remember that! It's halarious! :D
So's half the otehr crap he does.
Users browsing this forum: bharp831, stewartp and 88 guests
