It is currently Sat Aug 23, 2025 3:59 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 24, 25, 26, 27, 28, 29, 30 ... 568  Next
PostPosted: Mon May 18, 2009 5:41 pm
Fitted the steering column - tightened up the rack U bolts fitted the steering wheel and adjusted the self cancelling indicators. fitted the horn button.
David L
PostPosted: Mon May 18, 2009 5:49 pm
Got stated on the "K". Some progress on the bonnet!!!
PostPosted: Mon May 18, 2009 6:58 pm
I'm Ernie , Where's Bert ?
cleaned out both carbys with kero, put back together and roadtested......still running crap..tommorow its back off with the bits and further cleaning and mixing and matching :roll: :evil: :cry:
00' Forester GT
PostPosted: Mon May 18, 2009 7:01 pm
rubed down inner gaurd for final coats of gloss black and also scorred a clean clubby wiring loom for $9 8) perfect for me to add to mine to hide all the wires :wink:
PostPosted: Mon May 18, 2009 8:06 pm
Bought mine a friend
Needs a bit of work, but will come together well, hopefully with a 4efte :lol:
PostPosted: Mon May 18, 2009 9:23 pm
Picked mine up from the trimmers today took her home and put all the new chrome interior trim parts back on she looks so good, the blue pipeing just works so well. The wife was right (for once). :D :D :D
It might only have half the engine but its got 4 times the handling...............
PostPosted: Mon May 18, 2009 9:30 pm
Ill just add to this..I'm suprised some Mini don't just go up in a ball of flames :shock:
PostPosted: Mon May 18, 2009 11:46 pm
been 2 busy working to do any thing i have the engine out at the moment
waiting a 2nd gear rebuild seems though that i need 2to re tap the holes in
my fly wheel as i striped 2 bolts trying to remove the bl**dy thing and now the holes are full of 3/8th low grade balt oh well guess them the breaks
PostPosted: Tue May 19, 2009 12:39 am
Tomboss Breweros
Found a 3/8 UNF tap..... ^^^^
Sanded, hopefully the last, i can polish tomorrow :D
kimini wrote:
Jimmyinamini wrote:
PostPosted: Tue May 19, 2009 8:50 am
I put a badge on it ,
PostPosted: Tue May 19, 2009 8:54 am
ginger ninja
ginger ninja
looking good Ian.
I checked Cherry hadn't washed away in the downpour we had this morning
sports850 wrote:
PostPosted: Tue May 19, 2009 11:29 am
went and got a centre exit exhaust fitted.
on the way there i discovered the flasher can was playing up for the RHS so have got a temp flasher from supercheap. fixed the mixture up a bit, but cant find any timing marks anywhere.
anyone know where there should be timing marks on a 998 A+? cant see any marks/notches on the crank pulley and couldnt see anything on the flywheel
PostPosted: Tue May 19, 2009 11:52 am
Isn't that 850 badge worth more than the car these days?? :lol:
PostPosted: Tue May 19, 2009 12:27 pm
If it was just the badges by themselves and the car didn't have the matching history they probably would be worth more than the car :P
PostPosted: Tue May 19, 2009 12:42 pm
it's not what I did to the mini, but what the mini did to me...
decided not to drive the mini to work today.
hopped into the xtrail, reversed 1 meter.. bang straight into the bluestone wall.
karma?
tim
Users browsing this forum: No registered users and 219 guests
