It is currently Thu Jul 17, 2025 9:32 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 21, 22, 23, 24, 25, 26, 27 ... 568  Next
PostPosted: Wed May 13, 2009 11:52 pm
I knocked the floor out of mine on a concrete kerb :cry:
PostPosted: Wed May 13, 2009 11:55 pm
Tomboss Breweros
Crap, that sux.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu May 14, 2009 6:36 pm
I is a mookenik
changed the steering rack which went well except the whole reason i changed the rack is still there grrr :evil:. stupid knocking noises
PostPosted: Thu May 14, 2009 6:44 pm
Got out the other day.....moved the 5 engines delivered around the shed so I hav some room. got 2 12g295 heads and 2 12g202 heads.
Cut up some wood but thats another thread.
61 van
63 countryman
63 saloon
67 auto
73 auto clubman
75 1000cc clubman
77 sccr 998 clubman
NZ 79 1275gt clubman estate
79 LE
80 meanee
Racecar
Fiat 500
PostPosted: Thu May 14, 2009 7:43 pm
Managed to gather up all the assorted mini bits, cleaned and sorted them all into containers for the various size nuts, bolts and washers and discarded everything that has seen better days. Managed to find some of the more obscure fittings that I have often looked for. No excuse now for not putting things in the right place when dismantling minis.
1964 998 Cooper , 1968 Morris 1100
PostPosted: Thu May 14, 2009 7:57 pm
New Spark Plugs, and it's happy again. :D Running smooth as ever, idling higher, even works with the grille on. :lol: Given that every time I'd put the grille on it'd find a problem, I was starting to think that the grille was the problem for a while there... :roll: But no, it's not the fact the grille does push on the HT leads. :)
PostPosted: Thu May 14, 2009 8:01 pm
pack the grille forward a bit like the Cooper S was.
I use a couple of old Pulsar dizzy drive dogs...:mrgreen:
PostPosted: Thu May 14, 2009 9:39 pm
I put fuel in it today :-)
PostPosted: Thu May 14, 2009 10:28 pm
Took the clubby for a rego check..... :?
Finally found out why I got flagged for a check.... someone left out a digit in the body number when entering into the computer ! :roll:
Failed on brake lights/tail lights wrong way round (brightness) (PO wiring).... only been tested at least 5 times with this same setup ...
and exhaust touching body......
So just drained the fuel tank and removed (with the stupid drain thingy underneath :x ) took out the tank... swapped the lights electrical connections .. (checked lights)....
put it all back together again... (and didn't freeze to death in the process :) )
And hopefully "adjusted" the exhaust hanger sufficently to get clearance to make them happy......
try for another inspection in the morning....
PostPosted: Thu May 14, 2009 10:48 pm
Umm - why didn't you just swap the connectors in the corner of the boot opening ? or were they jambed in behind the tank - I know the tank is in the way but I could still get at the connectors with trhe tank in place. :?
David L
PostPosted: Fri May 15, 2009 8:06 am
Best way to fix that stupid PITA drain thing is toss it, and screw a short 3/8 UNF grubscrew in there with a bit of Loctite. :wink:
If it was necessary, how come RH tanks don't have `em... :lol:
PostPosted: Fri May 15, 2009 5:52 pm
didn`t do diddly on it today ,,, i was surfing in Byron all day :-)
PostPosted: Fri May 15, 2009 6:40 pm
Got it started for the first time since ive owned it...yay :D
PostPosted: Fri May 15, 2009 7:03 pm
My first thought but yep - seemed to be jammed behind the tank... no slack in wires...
Looked for something suitable in the garage .....but could not find anything.... but will chase up something for "long term".
(Even contemplated using the old 998 LS tank that doesn't have this feature -
but as it's been sitting around since about 1987 ...
thought it may need a cleanup first (and even back then had had to get repaired due to rustiing! ))
Now rego'd again. :lol: ... just took over 20 minutes to convince the Rego computer to accept the correct body number :roll:
PostPosted: Fri May 15, 2009 7:36 pm
I think we should call you The Prune
I didn't do anything Mini today but I had a Nap today While Owen was sleeping :shock:
I have have few new idea's now and know what i'm expecting now :lol:
