It is currently Sat Aug 23, 2025 8:33 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22, 23, 24 ... 568  Next
PostPosted: Sun May 10, 2009 11:02 am
It works out to be approx 1 foot per 4 hours!
Measure it twice, cut it once as they say!
I dont see the sence in doing it half arsed, you will only have to fix it again down the track!
mooo, I'm a pig!
PostPosted: Sun May 10, 2009 11:42 am
:( I looked at it and wished i was able to go on the run up to Kinglake........but its mothers day and I would have been "in more trouble than Falsh Gordon" if I was anywhere else but home:!:
PostPosted: Sun May 10, 2009 12:06 pm
was going to take it and my mum up to maclean's bridge
no go :(
it didn't start took the triumph instead :lol:
PostPosted: Sun May 10, 2009 3:22 pm
redid the c.v. boots ( and actually installed the circlips 8) ) jeeze the first one took me ages............. i figure out ho w to do it tho and the 2nd one took 5 mins.
and test drive all seem s to be ok.. :lol:
PostPosted: Sun May 10, 2009 5:19 pm
Tomboss Breweros
paint
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun May 10, 2009 5:37 pm
I drove mine! :D
to kinglake, with mum in the passenger seat.... was fun
Size DOES Matter!!!
PostPosted: Sun May 10, 2009 5:38 pm
took it out for a little drive to blow the cobwebs out.
ferntreegully to croydon ,lilydale.yarraglen,st andrews.kinglake.pheasantscreek.kinglake,marrysville,yarraglen,lilydaleand back to ferntreegully.just a little run. :lol:
PostPosted: Sun May 10, 2009 5:59 pm
The Mini King
I love this. My Dad, Rest His Soul, used this saying and so do I But most people look :? when I say it
PostPosted: Sun May 10, 2009 6:16 pm
That's because you are very old and drool when you say it, besides it sounds like your saying "Gerg gave me this rash on my ........" :shock:
PostPosted: Sun May 10, 2009 6:23 pm
The Forkmeister
Hey!!, leave me out of this.... :roll: :D
May the fork be with you.
PostPosted: Sun May 10, 2009 6:28 pm
Adjusted the timing a little, and enjoyed the improvement around the local block...
PostPosted: Sun May 10, 2009 6:42 pm
I spent the best part of the weekend sorting out a gear lever rattle and floor vibration, when I did the recon run for the GOR Tour I hit a concrete gutter ,unbeknown to me I actually rammed a bolt through the floor. It was only when I was finally happy with how the gear lever was sitting with no rattle that I found the hole where the bolt used to sit by cutting my finger on it, so next weekend its out with the mig welder. I fixed the gear lever by adding two extra washers above the spring and packing grease into the spring, taking the gear lever in and out a few times doesnt sound like it should take long, but its the lining up the four screws through the frame and boot rubber to the floor that takes a while.
PostPosted: Sun May 10, 2009 6:56 pm
Nothing!
PostPosted: Sun May 10, 2009 8:33 pm
Saturday I adjusted Tappets, did up uni joint boots and installed new clutch MC and got it bled and working.
Today I started installing my new wiring loom.... its real purdy like and cotton wrapped. I just need to work out what the hell I am doing... wish me luck!
PostPosted: Sun May 10, 2009 8:51 pm
started it for the first time in about 3 months
Users browsing this forum: No registered users and 198 guests
