It is currently Mon Jul 07, 2025 8:42 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21, 22 ... 568  Next
PostPosted: Thu May 07, 2009 10:14 pm
This space for rent
Had another go at getting the van to run properly over about 3000 rpm... without success :evil:
Although I can at least hit 110km/h now, I just can't hold it up any sort of hill. I'm beginning to think some clown has had some fun with a can of expanding foam... I can only get 13L into the 27L fuel tank, and it won't rev..
PostPosted: Thu May 07, 2009 10:24 pm
pulled my speedos out of both minis as both have recently decided to stop working!!
GRRR And pack them off to Otto Instruments in Brisbane 8)
PostPosted: Thu May 07, 2009 10:36 pm
rehab1964 wrote:
niceboy1275 wrote:
I fitted all the tail lights, put in all the interior trim and put the bumpers back on my matic.. also hopefully to be ready for july :D
not June for Hay then?
My matic at Hay? I doubt she'd go fast enough to use the handbrake... No, ready for minishow....
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
PostPosted: Fri May 08, 2009 3:16 am
The TIG
gafmo wrote:
TurboOrangie wrote:
I showed my friend some of my Mini projects. Then I drove his D15 powered VTEC Mini.
Okay TurboOrangie I want pic's Thanks...as you would expect :wink:
I didn't take any of my own pictures. He still has some assembly of final bits. But here is a link to his build.
http://www.16vminiclub.com/forums/viewtopic.php?t=14507
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Fri May 08, 2009 3:52 pm
Location: Burpengary,Brisbane Nth(the better side of Bribane)
walked past it and thought, naa, tommorow I will do somthing
https://t.me/pump_upp
PostPosted: Fri May 08, 2009 3:59 pm
The TIG
Worked on seat mounts for passenger seat in Travelle"R".
PostPosted: Fri May 08, 2009 4:07 pm
ginger ninja
ginger ninja
contemplated bathing it tomorrow but decided against it. Will be packing up mini parts to take to new place. Have lots of little side mirrors and such that are no good to me
sports850 wrote:
PostPosted: Fri May 08, 2009 4:10 pm
I have heard that about your driving :twisted:
PostPosted: Fri May 08, 2009 4:26 pm
Welded the exhaust pipe halves back together (MiniSport suggested cutting in half - reduced freight from $64 to $18 for shorter parcel)
DIY'd a heater pipe baulkhead plate by drilling two 1" holes in the original flat plate ( the hole saw just made it before dieing :roll: )
Cannibalised two starter motors to make one good one and blinged it up with a coat of black paint and now I'll play around with electro zinc plating the cover band on the end.
Worked out where the springs go on the twin carby setup.
Found out Mini engines are born with oil leaks :evil: My helicoiled sump plug hole is leaking :evil: :evil: :evil:
David L
PostPosted: Fri May 08, 2009 10:21 pm
Washed my Mini for the first time since I bought it. :D :oops: That's a little over two years. It got wet about a year ago, and has been dusty since. Now it gleams again. :D And I can see all the chips and nicks in the paint. :( 7 month old sat in the passenger seat (inside a booster seat, with the belt on) while I pushed it from where I washed it to where it's garaged. :D
PostPosted: Fri May 08, 2009 10:33 pm
Dragging my mini into the 20th century with accurate and readable gauges..
PostPosted: Fri May 08, 2009 11:39 pm
This space for rent
Had another go at getting the van to rev, and slowly slowly, I think we're making progress :D
PostPosted: Fri May 08, 2009 11:40 pm
Hhhmmm,,,, didn`t work on it today either,,, took a couple of people for a spin in it tho :-)
PostPosted: Fri May 08, 2009 11:44 pm
This space for rent
Geez, you're a lazy bugger.. :roll:
PostPosted: Sat May 09, 2009 12:30 am
Yet another day full of mini tasks... had to show dude at panel shop how to put the door bits back on priscilla lol :roll:
But I got to drive priscilla today!!!! oh... I missed that sooo much :)
Size DOES Matter!!!
Users browsing this forum: Bing [Bot] and 94 guests
