It is currently Fri Aug 22, 2025 12:19 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 568  Next
PostPosted: Wed Apr 29, 2009 4:51 pm
nothing :-)
PostPosted: Wed Apr 29, 2009 5:26 pm
The TIG
Today I bent up about 7meters' of tubing for the cage on the Travelle"R". The cage will have about 24 meters of tubing weighing about 64kg by the time I'm done.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Wed Apr 29, 2009 6:12 pm
well.. i know it's a bit late to start, but about to fix a fuel leak that just sprung up some time over the last two days...
fun fun fun!
tim
PostPosted: Wed Apr 29, 2009 6:44 pm
Tried to get the bloody thing to start!!!!!!
:cry: with no luck.....
PostPosted: Wed Apr 29, 2009 7:07 pm
Overheated it again... :P
PostPosted: Wed Apr 29, 2009 7:12 pm
Went round and round Wakefield Park running in the motor :P
PostPosted: Wed Apr 29, 2009 7:14 pm
:twisted: :evil:
This time it's BC that aint workin dagnabit!
Location: Burpengary,Brisbane Nth(the better side of Bribane)
Fitted a new clutch lever arm, slave cylinder pushrod and new clevis pins and guess what....................... I can get it into 1st gear really easy :lol: , total cost around $60 including freight. Gotta wonder why I didn't do ages ago. :?
https://t.me/pump_upp
PostPosted: Wed Apr 29, 2009 7:54 pm
Broke traction in 1st gear at 5K (shssh, don't tell anyone...) :lol: :roll: :roll:
PostPosted: Wed Apr 29, 2009 7:55 pm
You didn't have a P Plater Next to you :shock:
PostPosted: Wed Apr 29, 2009 8:12 pm
fun fun fun!
what a terrible job to do to get that fiddly little hose between the fuel pump and the pipe back to the tank on and clamped up.
ran out of hose clamps, had to remove the fuel filter and pinch them from that. someone on here said its ok to run an SU without a filter? if not, big trouble!
surprised it was still drivable.. the old hose was just overlapping the fuel pump connector, gravity fed I think!
tim
PostPosted: Wed Apr 29, 2009 8:38 pm
Got a quote for a repsray and the rust cut out, the body shop strongly reccommended getting a new shell to build it into :cry:
PostPosted: Wed Apr 29, 2009 8:42 pm
cutting and grinding off more metal parts to remove all rusty and damaged bits.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Apr 30, 2009 12:34 pm
This space for rent
Last night:
  • Fitted a new Smiths clock where the old 2" tacho used to be. Looks schweeet and now I can tell the time 8)
  • Pulled out the oil pressure relief valve and replaced it with a 15mm (9/16") steel ball, 40x8mm rod in the spring, etc. Oil pressure is now doing odd things -- At idle, consistently reads 65psi hot then as revs rise it flutters heaps then drops to 50psi and stays there above about 1500rpm. Might have to play with the spring pressure a little methinks.
  • Fitted an 88* thermostat, since I'm doing mostly 10km-at-a-time trips at the moment and my oil quality is suffering through not getting hot enough. Took two goes at getting the housing to seal, ended up running a bead of HT silicone with the gaskets and leaving it overnight to cure.
This morning:
  • Started the car, observed coolant still dripping out of the thermostat housing :evil: Cleaned all the surfaces again, replaced the gaskets again, ran another film of silicone and reassembled. Waited an hour, then fired her up -- perfect seal this time :roll:
  • Noticed the water pump making unhappy noises, looks like a job for another day...
PostPosted: Thu Apr 30, 2009 12:44 pm
awdmoke and I have the same thing happening, higher pressure at idle than at revs - I was gonna try a bigger ball. Let me know what works ;)
doncha hate that...
ummm, I drove it to where I'm working today, gonna change the oil tonight, and maybe have *another* go at wheel alignment
