It is currently Fri Aug 22, 2025 4:28 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 568  Next
PostPosted: Tue Apr 28, 2009 7:19 am
I rebuilt and blinged my carburettor..... for my Matchless
PostPosted: Tue Apr 28, 2009 7:55 am
Tomboss Breweros
Finished my uber cool door trims.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Tue Apr 28, 2009 9:52 am
put feul in it and now going to work
PostPosted: Tue Apr 28, 2009 5:11 pm
The TIG
Bought some welding wire, welding rod, new liner for my MIG, new floors for Traveller 2 and some patch panels for the anterior mounts for the rear subframe. Played with the electrical system on Traveller 2 and dropped off a couple generators and some voltage regulators at my local shop the rebuilds electrical components. I jacked up the rear of Traveller 2, built a contraption to hold it up in the air and I removed the rust that once was a subframe. And I sold some headlight rings. Oh, I almost forgot, I also removed the thermostat housing which was pretty seized on and it was pretty gross and plugged up. Also forgot about carefully hammering out a small crease/dent down the rear left side. Came out quite nicely.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Tue Apr 28, 2009 6:01 pm
Bought a new MIG torch with lead to replace the one that won't shut off the gas supply. Now I can weld up my exhaust pipe cut in half to reduce the postage :roll:
David L
PostPosted: Tue Apr 28, 2009 6:48 pm
Im goin out to hav a look........I might just turn around then walk away.......Who knows I might be inspired to do something.......I gota look for a steering rack for my mate.
Hope I get inspired :D
61 van
63 countryman
63 saloon
67 auto
73 auto clubman
75 1000cc clubman
77 sccr 998 clubman
NZ 79 1275gt clubman estate
79 LE
80 meanee
Racecar
Fiat 500
PostPosted: Tue Apr 28, 2009 7:23 pm
Kicked the farking thing. Clutch this clutch that, now thrust bearing is whining like a little bitch. So i feel like kicking it again.
PostPosted: Tue Apr 28, 2009 7:53 pm
Location: Burpengary,Brisbane Nth(the better side of Bribane)
bought some new tyres for my new rims and put them on my car.
https://t.me/pump_upp
PostPosted: Tue Apr 28, 2009 7:55 pm
PICTURES!!
PostPosted: Tue Apr 28, 2009 7:57 pm
Give Ash some flowers Nick .
d1ck0 wrote:
PICTURES!!
http://www.ausmini.com/forums/viewtopic.php?t=50373&postdays=0&postorder=asc&start=15
PostPosted: Tue Apr 28, 2009 8:08 pm
Thanks 1018cc. :)
PostPosted: Tue Apr 28, 2009 8:44 pm
Fitted ARP wheel studs to the rear hubs on the racecar. Pulled the rear end apart and blast beaded all the parts. Waiting on good weather so I can paint.
Member VMCI #19
PostPosted: Wed Apr 29, 2009 1:48 pm
Ordered some bits from MiniKing
David L
PostPosted: Wed Apr 29, 2009 2:09 pm
installed my reground crank into 1310 block,took it over to mini autos,where ken made sure the thrust clearance was correct,cam followers installed,cam,timing chain and oil pump.very productive day....
First you get the money,then you get the power,then you get the Mini.
PostPosted: Wed Apr 29, 2009 4:46 pm
I nearly pulled the steering column off.....while driving.
Goes into a different mechanic tomorrow morning to have all the previous crap work repaired :)
Users browsing this forum: No registered users and 288 guests
