It is currently Fri Aug 22, 2025 12:19 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 568  Next
PostPosted: Mon Apr 27, 2009 5:10 pm
Felt very ashamed after reading the activity that has been going on- did however admire my POR 15 work on subframes, and packaged calipers for resleeve-keep up the good work it will get me motivated.
PostPosted: Mon Apr 27, 2009 5:15 pm
Milatsmadmini
bought a few goodies for the moke today.... (rover alternator, air die grinder with 4 burrs....mmmmm.....)
thinkin i need to organise a "garage day" for my moke.... quiet a few things that need doing....
PostPosted: Mon Apr 27, 2009 5:33 pm
HEAPS
Hung some bits off the engine after giving it a second coat of paint. Purchased an adapter for the temperature sensor and fitted it to the thermostat housing.
Found I had put the dizzy drive in 180° out so fiddled with it - taking out and putting back - out and back a couple of times to get the slot pointing at 1 o'clock when #1 is TDC
Modified the Maniflow 3:1 manifold so the nut and washer would fit around the welds on either end plate then fit it
Added the twin carby set up on the manifold (note to self - remove carbys AND heat shield to remove if need be in situ.)
Fitted the clutch end breather
Then spent ages looking for a couple of things I put in a safe place 8 years ago when I dimantled the engine - still not found :evil:
David L
PostPosted: Mon Apr 27, 2009 5:36 pm
we towed the Nota on a rope 97 k's
PostPosted: Mon Apr 27, 2009 5:40 pm
Learnt that it's easier to connect the brake lines when the engne is out. :roll:
Put engine back in.
Installed thermofan
Installed electric water pump.. Just need to turn it on and test it.
Installed new heater tap clubby type
Installed 4 pot calipers
Installed new front arms, hopefully will drive straight now and not scrub out tyres after 5000 km's
tried and succeeded in doing up brake lines on the drivers side.
Now just need to do the wiring and change the rear wheel cylinders to suit.
2008 Prado GXL
PostPosted: Mon Apr 27, 2009 5:45 pm
ginger ninja
ginger ninja
you guys should all be so proud! Quite a productive lot you are.. Makes me feel like i'm neglecting my mini
sports850 wrote:
PostPosted: Mon Apr 27, 2009 6:19 pm
I is a mookenik
i replaced my starter solonoid. bought some gauges just need to install them.. worked out why my brakes were making a scratching noise under heavy braking...
PostPosted: Mon Apr 27, 2009 6:49 pm
pulled off hubs to replace wheel bearings and ball joints.
Replaced the wheel bearing and ball joints. Man that takes some time to do with the testing, undoing, add a shim, do up, test, undo, ad another shim, do up, test, undo, take off a shim an pput a slightly smaller on on..... blah blah.
Managed to break two grease nipples.
Went to repco and when I walked in the guy said what can I help you with and without thinking is said can you show me to the nipples? Could have been worse, could have said can I see your nipples?
PostPosted: Mon Apr 27, 2009 7:05 pm
Location: Burpengary,Brisbane Nth(the better side of Bribane)
tried to fit my Zeemax bodykit to my deluxe project :evil: I think it will take a few more beers to make it work .
https://t.me/pump_upp
PostPosted: Mon Apr 27, 2009 7:11 pm
Pulling *insert name such as scrapper, basher, etc. here* off the trailer (not my trailer)... between the rain showers.
PostPosted: Mon Apr 27, 2009 8:29 pm
I fixed the annoying rattle on my gearstick. And took a test drive out to dayboro, and cruised at 110 which i was very pleased with.
PostPosted: Mon Apr 27, 2009 8:41 pm
Blinged :shock:
PostPosted: Mon Apr 27, 2009 8:45 pm
Milatsmadmini
gafmo wrote:
Blinged :shock:
everything you touch Jimbo..... everythin you touch :lol:
PostPosted: Mon Apr 27, 2009 9:21 pm
put sum radiator flush in me cooling system last nite, drove to trade school today
removed radiator reverse flushed for about 45minutes.
radiator contents look liked a giant peice of cow dung,
reverse flushed engine
engine contents look just the same
cleaned all thouraghly, painted radiator, shroud, brackets and thermostat housing.
put back together, added some moderatly priced tectaloy coolant.
only sits half way between cold and normal now. on a cold adelaide day
very impressed.
PostPosted: Mon Apr 27, 2009 10:42 pm
doesn't take much to get a mini running cool, does it...
today I had a heating problem, I hadn't done up the locking screw on my heater tap, so when I pushed in the knob on the dashboard to open it and let water flow into the heater, it didn't, and I was left with the heater blowing cold air on my feet :cry: :cry:
so when I got home I tightened up the screw :wink:
