It is currently Fri Jun 27, 2025 8:26 am
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Feb 25, 2005 8:14 am
Apparantly sifting without clutching puts all the load of the excess revs on the synchromesh rather than on the clutch meaning that you stuff your synchros faster and it is sooner that you have to rebuild your gearbox. :cry: When told that I stopped playing around with shifting without a clutch :oops: :cry:
Roads need more corners
PostPosted: Fri Feb 25, 2005 8:31 am
CLUBMAN wrote:
hey,
i took my car for its first drive on the road on wed's,DAMN i couldnt get gears,its tighter than all the crusty rod boxes im use to driving.i would still like a KAD short shift..
My rebuild remote box is tighter than big willies rod box with short shifter :lol:
I can beat the synchros on my remote change gearbox, they're probably pretty old but there is no way they would take a quicker gearshift than what you can do with the standard gearstick
PostPosted: Fri Feb 25, 2005 10:05 am
i just wanna try the quick shift so i can say iv done it and yes i like it or no they are a waste of time,im going for a propper "hoon" 2day so ill get abit more quality time in with my gearbox...WILLIE you need to come around 2nite so we can bleed my clutch,hasnt been done since motor went back in :shock:,still dont crunch reverse so its alrite for now
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Fri Feb 25, 2005 10:26 am
me and john can come round :D
Nigel Morton/ Team Brickworx
never late in a 998
PostPosted: Fri Feb 25, 2005 10:35 am
are you gonna go for the one on ebay atm ?
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 30225&rd=1
PostPosted: Fri Feb 25, 2005 10:42 am
LOL,then i can have john BL going,did ya want the wrench eavrytime i pop my head up,LOL
yeah its my Bday so come over 2nite :lol: we can have a fue drinks while pissing around the my mini..good times
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Fri Feb 25, 2005 10:43 am
i prob should have a shot at the quick shifter on Ebay,but i need to spend my money on my weber manifold,as im thinking of getting one like the doc's but have it already done :D along with his RE13 cam
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Fri Feb 25, 2005 1:48 pm
yeah those manifolds are prettydamn good.... I saw his old one and it was impressive, nd the new one apparently even better! 8)
$250 though arent they?
68matic: "i havent seen much head in my life "
PostPosted: Fri Feb 25, 2005 3:47 pm
i think they is $260..but from what doc says,from the manifold alone it started to pull 100RPM lower and kept pulling 100RPM later,worth a shot,and i suppost them manifolds would have been tested with his cam,wich it will be getting all at the same time :D
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Fri Feb 25, 2005 9:31 pm
at any rate it doesnt make much difference for me... I jut have to get the carby converted... i am using a mini spares centre manifold which apparently pretty good...
