It is currently Thu Jun 26, 2025 12:49 am
Post new topic Reply to topic  [ 1864 posts ]  Go to page Previous  1 ... 50, 51, 52, 53, 54, 55, 56 ... 125  Next
PostPosted: Wed Feb 11, 2009 10:25 pm
yeah tricky,,, common man i`m getting withdrawalls waiting for some more progress reports on your beast
I`m learning alloy tig at the moment with my machinist,,, his welds are just the very best i`ve ever seen & it looks so easy to do tho,,, havn`t quite got a good hold on the foot peddle yet tho, it`s a bit like learning to play the piano :-)
keep up the good work mate
PostPosted: Thu Feb 12, 2009 12:18 pm
The TIG
Archangel007 wrote:
Yep Nigel, the plasma cutter is definitely on the shopping list!!!!
I will just be doing std aluminium Nigel - 6061 so I got the general purpose rods that suit the 6XXX series aluminiun.
I havent tried welding stainless or aluminium yet, but I think I will give it a go this weekend.
What other toys have you got?
Tricky
I sure enjoy welding aluminum, I find it both stainless and aluminum a little easier to get a nice bead with than mild steel. If you have the right rods.
I don't really have much that is exotic, just some hand tools, couple air tools, some angle grinders and various pullers etc I've picked up during various projects. I eventually want a lathe and a milling machine, but that might be a while. However I just found out one of my good friends is currently shopping for both a lathe and a milling machine, so I'm pretty psyched. He is also going to help me build a cage for my car. He's got tubing benders and notchers etc. However, he is usually building cages that go on the outside of 4x4 trucks. But he does nice work.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Fri Feb 13, 2009 7:17 pm
Hi Guys,
Just been doing a bit of shopping of late, I now have bought a panbrake, plasma cutter and pipe bender to go with the new TIG.
I used the plasma cutter for the first time on the weekend, man, what did I ever do without this little machine, they are awesome. It is rated at 50amps max, and they state it will cut up to 16mm plate :shock: Intricate shapes are a POP, and even though I was only doing 4mm thick 50x50 RHS (making the stand for the pan brake) on the weekend, it cut like a knife through butter on 10amps. It is so easy to cut straight lines pencil thin freehand.
Pictures:
Here is a pic of the 'boys' altogether - 200Amp TIG, 50Amp Plasma, 135Amp MIG, and 150Amp Arc. I made up the trolleys so that they could be ultra portable and flexible. Thats the end of my welding machine purchases for good I should think.
The gas bottles are all held securely, and the vertical PVC tubes on the TIG stand hold all my rods - mild steel, alloy, stainless steel and CrMo. As you can see, nice neat self-contained and totally portable units.
And this is the panbrake I bought, it weighs 170kg without the stand and can bend 1.6mm steel along its entire1200mm length. I will never bend anymore than 1.6mm so this will do me just fine. Its actually a box and pan brake, with removable and adjustable fingers so you can bend up boxes, and other shapes with internal bends.
And with the stand that I knocked up on Saturday. With the plasma and the MIG it was fabricated in a a matter of hours from scrap lying around.
And this is the pipe bender I am waiting on. I have the plans for this on my laptop (if anyone wants them), and I got all the steel laser cut here in Brissie for $400. The retails price from Sydney was $750 plus freight. The dies are of course extra (about $500 per die). It will bend up to 50mm tube/pipe, and 50mm RHS.
It is not a true mandrel bender, but a 'friction' bender, that draws pipe along a die to maintain the shape. It doesnt crush the pipe like a compression bender. It will do up to 5.0mm wall thickness on 50mm pipe.
So now I'm just about to pick up some alloy sheet so I can bend up the air filter box with the new panbrake on The Cat, and then weld it up with the new TIG. Then I can finish fabricating the alloy charge air pipes, and its essentially finished ready for painting.
So, now all I'm waiting on is the Mill and Lathe, just like Nigel! Nigel, race on then?
Tricky
PostPosted: Fri Feb 13, 2009 7:21 pm
I want toys like yours...... 8)
PostPosted: Fri Feb 13, 2009 7:38 pm
Cant wait to see some of the things that you are going to produce Tricky!!
Life's a garden.... Dig It!
PostPosted: Fri Feb 13, 2009 8:28 pm
This space for rent
Wow :shock:
Love the branding on the pan brake.. macho 8)
PostPosted: Fri Feb 13, 2009 9:58 pm
OK Tricky, now you've succeeded in making us all really jealous of your toys, why not at least give the people a photo of El Gato. It's what they are hungry for.
And when you say those welding trolleys are mobile, just how mobile are we talking here...
Fancy a holiday in smoky Victoria to finish off a certain Morris...
Madmorrie
PostPosted: Fri Feb 13, 2009 11:44 pm
ok,,, that`s it,,, i`m comming to work for you Tricky :-)
PostPosted: Sat Feb 14, 2009 7:48 am
C'mon over Matt, I could learn a lot from someone with your wealth and years of experience!
MM - yes, totally portable. Smoking Victoria, sounds inviting! :D
Give me a couple of days for a revised pic of El Gato, should have the airbox done by then! Patience, people, patience.
Tricky
Matt/Nigel - what do you think of this for a mill??
Website:
http://www.siegind.com/Products/br-x3-super-lathe.htm
Test here:
http://www.mini-lathe.com/X3_mill/Sx3rvw/SX3-4.htm
PostPosted: Sat Feb 14, 2009 8:50 am
A mill too? You no longer have a garage, it's a true workshop.
PostPosted: Sat Feb 14, 2009 11:58 am
Ah Tricky, that`s just cheap chinese crap mate,,, send it over to my place & go buy yourself a decent one :-)
we use these old dungers--->
pretty old now, but (when it`s working) cam make some pretty funky things :-)
& this new one,,, Haas 5 axis ,,, farking amazing thing
all 3d stuff , half of which we don`t know how to use properly yet :-)
wish they were mine tho :-(
I`m still comming to work for you tho :-) & you won`t learn anything from me that you don`t already know mate,,, Trying to be all humble & modest doesn`t work with me :-)
more likely i will be learning more fabrication stuff from you :-)
PostPosted: Sat Feb 14, 2009 7:35 pm
Fark Matt, if I had access to that kind of equipment I wouldn't be leaving the shed!!
I would love to have 5-axis CNC machine, if the funds allow, but unfortunately they dont (plus it would take me 6 months to learn how to use it).
The Seig Super X5 will do me for all the things I need to do - brackets, mounting plates, spaces, shafts, splines, tools etc so for now it will do just fine. I am quite excited about getting one, even though its a couple of months off.
The lathe will come before the Mill though.
I reckon we should do a JV sometime in the future to cross-pollinate our collective knowedges.
Tricky
PostPosted: Sat Feb 14, 2009 8:29 pm
This space for rent
With the thought of Tricky and Matt joining forces, there are times I'm glad to be in Melbourne :lol:
PostPosted: Sat Feb 14, 2009 10:15 pm
hee hee,,, physically laughing my guts out as i type this
& that is the 2nd time tonight david Rosenthal PM`d me & dam i`m still laughing,,, & then you come up with the cross-pollinate thing :-) ;-) :-) Ahhh gotta love this forum sometimes hey?
cheers guys
& Tricky,,, i will have to drop in & say gidday one day shortly,,, PM me your ph number & i`ll sort a time after the next couple of weeks,,, i`m off surfing at Byron for most of next week,,, then we have an Autocross at Willowbank next sunday, but after that sometime...K?
PostPosted: Sun Feb 15, 2009 9:53 am
Give Ash some flowers Nick .
*jaw drops*
El Gato is going to be finished off to a higher standard now than it ever was....and it was a very high standard before :shock:
And I am very jelous of all your toys!
Users browsing this forum: No registered users and 30 guests
