It is currently Wed Jun 25, 2025 11:42 am
PostPosted: Wed Aug 27, 2008 7:34 pm
Online
Some guys in the States with A/C put the condenser under the car, inside the rear subby- with a fan to blow air down through it. :wink:
PostPosted: Wed Aug 27, 2008 7:40 pm
My truck (Iveco Acco) has the condensor in front of the front left wheel, behind the bumper with a fan sucking on it. It is a very neat square unit, mounted on a 45° angle. (I wouldn't mind pinching one!)
It would go very well in the middle of the rear subframe. (the mounting angle would need changing)
PostPosted: Wed Aug 27, 2008 8:39 pm
Updated on the post I made near the top...
I have since fitted the 4efte, and air con? Not really. It's tight as all hell, my alternator is going in the guard it's that tight. I gues syou could possibly do a similiar system with a compressor but the engine mount is in the way, blah blah blah....
PostPosted: Fri Sep 19, 2008 8:31 pm
Die Die Die!!
seems there is a place that sells a/c kits for VTEC conversions or around $2500 not including postage
PostPosted: Sat Sep 20, 2008 2:15 pm
Minitec in US do I believe, however you need to buy an extended front also, and there is probably more room in the engine bay without an intercooler (unless you did top mount intercooler).
Nick, I had grand ideas of A/C toyota Mini, and I still think I will do it, but once you put the motor in, you then realise, wow, it's cramped I can't even fit my hand down there let alone a compressor.
But by all means go for it!
PostPosted: Sat Sep 20, 2008 2:20 pm
Die Die Die!!
way i see it a flip front extended by 2" isnt such a bad thing i mean 2" is nothing.. and flip front is awsome because it makes getting to the engine alot easier
PostPosted: Sat Sep 20, 2008 4:36 pm
Like I said go for it. I'm going to have enough trouble engineering and regoing a deseamed Mini because it's built after 1971 let along a fibreglass flip front. So it's really not for me.
PostPosted: Sun Sep 21, 2008 9:07 pm
What are the legality's on a Flip Front. Is it legally possible on a road registered Mini, or is it dependant on the Engineer you use?
Dicko
PostPosted: Sun Sep 21, 2008 9:11 pm
Like these two??
PostPosted: Sun Sep 21, 2008 11:21 pm
Die Die Die!!
yeah those are the ones ive been looking into.., cept im thinking their prices are a bit steep
PostPosted: Mon Sep 22, 2008 1:14 am
i think you will have issues wit legalities going fibreglass, steel cant see why that would be a problem!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Sep 22, 2008 8:14 pm
Pre 1971 not a problem after that it has to comply with crash tests so no way
4efte powered Clubman
supercharged 998 race car
PostPosted: Mon Sep 22, 2008 9:58 pm
Die Die Die!!
well here in adelaide we dont have regular check ups so i can have it for as long as i can get away with it..
