It is currently Sat Jun 21, 2025 11:29 pm
Post new topic Reply to topic  [ 219 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 15  Next
PostPosted: Thu Aug 14, 2008 8:12 am
(sigh) I need a TIG!! :?
PostPosted: Thu Aug 14, 2008 1:03 pm
The TIG
Yes you do need a TIG. Everybody building a car should have one. And a plasma cutter. Oh heck, we should have every tool known to man. That would be perfect. I mostly need a proper garage, hopefully soon.[/quote]
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Thu Aug 14, 2008 2:39 pm
Right then, time to go shopping!
That will go on the list with the lathe and the pan brake/guillotine/roller!!
PostPosted: Thu Aug 14, 2008 3:24 pm
The TIG
Don't forget a C&C milling machine and a water jet.
PostPosted: Fri Aug 15, 2008 8:11 am
Fark, there goes the tax return!
PostPosted: Mon Sep 08, 2008 5:08 pm
The TIG
Well, I did some more work today. I'm trying to get the shell ready for some primer but I have a few more things I need to do before it's ready. One of them required me to work on the gas filler. So I figured this is partly related to the engine swap part of the job so here is what I did today.
I wanted to smooth out the cut out in the side of the car and make the car a little safer as far as fuel being able to enter the car in case of an accident. But I had to do the modifications to the gas filler before I welded the recessed part to the car. I wanted to still run a stock looking gas cap so I welded the filler neck from the Traveller tank onto the smaller filler tube from the Civic donor. It was slightly smaller in diameter so I took some wedges out of the Traveller neck in a few places and did some hammer work and made it fit the smaller Honda tube. I also put a flange on to the neck so it could screw onto the car with a couple allen key bolts. Also I TIG'ed a couple nuts on the back so I didn't have to try and get a wrench up in there. I still have some work to to on the far end of the tube that will attach to the fuel tank with the Civic rubber hose.
Here's what I've got so far.
PostPosted: Mon Sep 08, 2008 7:11 pm
What fuel tank are you using?
PostPosted: Tue Sep 09, 2008 1:01 am
The TIG
I'm unsure what tank I'm going to use which is part of the reason I decided to make the filler the way I did. I'm going to have to modify whatever tank I use quite a bit so I might just weld up my own from scratch. The tank that was in it was a custom tank that somebody made for it, but it's just too heavy. I haven't weighed it, but you'd swear it is full, even when it is empty. I was shocked when I pulled it out. It was quite abit heavier than the Honda Civic tank was.
PostPosted: Tue Sep 09, 2008 7:58 am
Nigel,
Good work mate!
Just an aside, does your TIG double as a plasma cutter as well?
Tricky
PostPosted: Tue Sep 09, 2008 10:59 am
The TIG
The TIG machine doubles as a stick welder, but the plasma cutter is a separate machine.
PostPosted: Wed Sep 10, 2008 6:07 pm
dont you think you could fit a really big tank inside the rear subframe?
I was looking at that when dropping my tank the other month.
You could even fit an lpg donut in there i reckon.
D
PostPosted: Thu Sep 11, 2008 12:53 am
The TIG
That is a decent amount of room, especially without the recessed area for the spare tire in the rear cargo area of the floor. But I'm planning on putting the spare tire under there and the muffler, that doesn't leave much room. So I thing I'll keep the tank in the stock location.
PostPosted: Wed Nov 26, 2008 7:45 pm
The TIG
No pics. But I thought I would update this thread and mention I just did another 5 hours of work on the wiring harness for a total of about 15 hours. I sold the Mini wiring harness and I am replacing it with a complete Honda harness from the donor car. So I have stripped it right down and I'm going through removing what I don't need and I am making a few modifications. Some of the modifications are to change how some things work and some are to make the wires run where I want them to go. I did a test fit the other day so I could figure out roughly where things should go. After some more work I will test fit the harness again.
I think I'm a little sick, because I do enjoy the wiring especially all of the soldering, heat shrink tubing and taping everything back up.
PostPosted: Wed Nov 26, 2008 8:16 pm
Yeah, you are a crack pot.
PostPosted: Thu Nov 27, 2008 7:49 pm
Sick from sniffing the fumes off the solder! :shock:
